Buzzing Noise
Hello, I changed out my rear speakers and added a amp to power those rear speakers. It makes a buzzing noise. The higher the gain setting the higher the buzzing sound...
It doesn't get alouder as I drive... its not the whining noise that you hear when you your rpm goes higher.
Its just buzzzz... electric sound. If I turn down the gain... then it doesn't buzz.
If I turn it down enough to were I don't hear the buzz then its like not using an amp at all.
What can I do to resolve this issue?
how did you tune your amp. also is it off the stock head unit? you want to turn the gains all the way down then turn your radio up to about 90% volume then turn up the gain until it distorts a bit then back it off a hair. this will match it to the radio's output. if this doesn't work then change your ground location to a spot with less interference. this will help enliminate the noise if it doesn;t go away then return the amp for a new one.
I got a buzzing in my front right speaker. Not sure why it is there now. Hasn't been there for awhile but it makes the noise when I accelerate which usually deals with being to close to the power wire. But my RCAs and speaker wires are run down the right side of the car and my power is run down the left side. Only place they are remotely close is in the back where they hook up.
Well thats what I ment the speaker wire.
And no the power wire is run on the left side and everything else (RCA, Speaker wire, etc) is on the right side. Ill have to check the speaker wire.
kb1sxv
Oct 21, 2015 05:00 PM
Klashan
Sep 24, 2015 12:39 PM
Andreas24
Sep 15, 2015 02:10 PM
