A/C Vent output probs
Ok, so I dropped the LED's in the dash and now when you put the air vent on the first setting (the one to the bottom left) where air is just to come out the two vents next to the radio, the air comes out there and the bottom part of the console.
Any suggestions what I goofed up?
May not be a problem. Im not sure what you mean, but if you put your fan/blower on the lower setting, you may not be able to feel it on the outer to vents easily. Try putting the blower on high and see if it comes out of the side vents with any force at all. The outer two vents do have less force than the inner two, because they are farther from the blower motor- so its hard to feel it on the lowest setting.
Try it with high heat or full AC, and see if you can feel a temp change in front of the vents on lowest blower setting.
BlingSlade
09-05-2015 08:52 AM
