COLD CATHODE EXTENDER, bad idea?
Old Apr 25, 2004 | 11:32 PM
scionxbny's Avatar
Default COLD CATHODE EXTENDER, bad idea?
I have two open slots on my cold cathode inverters and and was thinking of entending them out to other areas of the car, to attach more CC's to. There are extender cables for this. From what i have seen the CC's are rated to a certain length. Will the lights become noticably dim if i do this? I have heard these extenders are a bad idea. Anyone know?
Old Apr 26, 2004 | 12:51 PM
Max2k's Avatar
They should be fine, but it'd probably be a better idea just to run a power wire and install another inverter.
Old Apr 26, 2004 | 02:14 PM
toybox1's Avatar
you can't extend them ..... they will be very dim if they work at all
Old Apr 27, 2004 | 04:08 AM
ikhonlord's Avatar
BUMp BUMP!!!
I have two open slots as well...
scionxbny where exactly do you want to put the other two cathodes?? In the trunk?? I think I saw a post of a guy who just tapped into a wire in the back and was able to get two in the back! Let me know!
Old Apr 28, 2004 | 12:15 AM
ghost's Avatar
N.G.S.O.
Don't extend the wire between the inverter and the tube at all. The lights will get dimmer.
Andrew
Old Apr 28, 2004 | 12:19 AM
Max2k's Avatar
It's really really easy to pull wires back to the trunk, all you have to do is pull the snap-on body panels off.
Old Apr 28, 2004 | 01:07 AM
scionxbny's Avatar
Could you explain? I have existing wiring that is all routed from the harness power supply under the e-brake.
randode
44
Jun 29, 2004 04:19 PM
Opr8r
25
Jan 13, 2004 07:42 PM
randode
Nov 20, 2003 05:46 PM
Besk_one
Nov 17, 2003 09:28 PM
BlueBox
9
Sep 25, 2003 04:36 PM
