Cold Cathode Install Help
Old Oct 7, 2004 | 05:46 AM
markritch's Avatar
Default Cold Cathode Install Help
hey guys i just bought a cold cathod kit for the tC. Can someone do a little quick walkthrough of the install on the tC. Best wire to splice into, best place to find the wire, and also the best connectors or tools needed to do this...Thanks guys
http://www.svc.com/v12inch2ccflblack.html
Old Oct 7, 2004 | 05:55 AM
smoger's Avatar
Default Re: Cold Cathode Install Help
I know this isnt specific to your car but i just installed some CC's into my srt-4..
the simplest thing to do is go to pep boys and look in the wiring section.. they sell an item called "add a circuit" . this is essentially a piggyback fuse.
all you do is replace one of your existing fuses with the add-a-circuit, plug the old fuse into it as well as the fuse for the new accesory(cc's), and then connect the power wire for them to the add-a-circuit(it already has a power lead attached to splice into). you can ground them anywhere you can find something bolted to the chassis(strip the paint under the bolt!)
good luck.
Old Oct 9, 2004 | 09:07 PM
Fujiz_xb's Avatar
sIcKsCiOnS
in case this helps
https://www.scionlife.com/forums/vie...er=asc&start=0
if not sorry..
but what smoger said..i bought the add a circuit and relay also a on/off switch. i have yet to install them
randode
44
Jun 29, 2004 04:19 PM
randode
Nov 20, 2003 05:46 PM
Besk_one
Nov 17, 2003 09:28 PM
randode
15
Oct 31, 2003 09:50 PM
BlueBox
9
Sep 25, 2003 04:36 PM
