Custom xB speaker install.
Old Feb 10, 2006 | 04:44 PM
ll's Avatar
ll
Default Custom xB speaker install.
I was rather dissapointed to find out that Toyota had chosen to use speakers with a non standard mounting shape.
I had some Lanzar speakers (from back when Lanzar made good audio equipment) that I knew would fit, but I was going to need to install custom (read: home made) baffels.
Here are a few links to images of what I came up with.
http://leland.sway.org/xb/DSC00128.JPG
http://leland.sway.org/xb/DSC00132.JPG
http://leland.sway.org/xb/DSC00133.JPG
I also built a box for a JL 10 that fits into the floor behind the rear seat (links below)
http://leland.sway.org/xb/DSC00302.JPG
http://leland.sway.org/xb/DSC00305.JPG
I am being a little lazy about the writeup, if you have any questions let me know.
-Ll
Old Feb 10, 2006 | 06:20 PM
SCI_TC_GUY's Avatar
pretty much everyone has made MDF baffles for the speaker mounts.... most aftermarket speakers have to have the 3/4" MDF inorder to have adequate mount depth...
good job on the floor, what space do you have in the enclosure?
Old Feb 10, 2006 | 06:42 PM
ll's Avatar
ll
its ~720 cubic inches. I decided that I would sacrifice performance for fit and finish. The amplifyer is mounted under the floor as well... The actual enclosure is really only just big enough for the sub.
The sound and response are reasonable.
Old Feb 10, 2006 | 06:50 PM
SCI_TC_GUY's Avatar
If you don't mind me making a suggestion, stuff that enclosure with some polyfill as the sub's being suffocated... at least make it "think" it's in a bigger box...
nice F&F by the way..
Old Feb 11, 2006 | 01:48 PM
SoCalMike's Avatar
Looks Good!! How about the back speakers. Do you need the spacer to mount anything in the back???? And will a 6 1/2 fit with no problems??? Thanks!!!!!
Old Feb 11, 2006 | 01:58 PM
BrianxB's Avatar
next time, take larger pics.
Old Feb 12, 2006 | 03:41 AM
Max's Avatar
Max
I modified the stock speaker housing for my 5.25" An MDF spacer would also work.
A 6.5" will not work without cutting, AFAIK.
Old Feb 12, 2006 | 05:50 AM
SoCalMike's Avatar
Thanks Max!!!
Old Feb 13, 2006 | 04:20 AM
FREQBOX's Avatar
3 layers of 3/4" birch and a 1/4 masonite base
brings the speaker out flush with my doorpanel and centers the speaker in the opening
metal mounting/cosmetic ring painted black
Old Feb 13, 2006 | 01:51 PM
Peter_Rabbit's Avatar
^^^^ wow nice install. Are the kickpanels custom if not where did you get them?
Old Feb 13, 2006 | 03:46 PM
superjeer's Avatar
That looks awesome. Is the imaging too low?
Old Feb 13, 2006 | 09:27 PM
FREQBOX's Avatar
kicks are totally custom build off factory kickpanel..my buddy owns a shop in So Cal he did the install work for me
Old Feb 13, 2006 | 09:30 PM
FREQBOX's Avatar
The imaging is really nice but i also have tweets in the a-pillars that brings the stage up really high
Old Feb 14, 2006 | 01:36 AM
one80ikyu's Avatar
I get jealous when I see those kick panels. I am considering buying some kicks from the dealer and having a go at the custom kick panels.
mischman
Sep 15, 2015 03:38 PM
TheGovernmenT
Sep 4, 2015 11:57 AM
umnitza
Sep 1, 2015 08:06 PM
chunkescion
Aug 13, 2015 09:14 PM
umnitza
Jul 25, 2015 07:54 PM
