DEI/Clifford Alarm Install Help
New here and needing a little help with installing a Clifford RSX 3.5 alarm & remote start system on my girlfriends 06 xB. I have the complete electrical service manual so locating the needed the needed wires is no problem. She has just he factory keyless entry system on the vehicle now with no aftermarket or factory installed alarm system.
I've already located; 12v constant, 12v switched, starter wire, accessory wire, parking lights, door pin, horn.
I have placed "?" out beside all the wires I'm unsure about.
Primary Harness
H1/1 - 200ma Channel 2 Validity Output - ?
H1/2 - Constant Power - Located
H1/3 - (+) Siren Output - Located
H1/4 - Not Used
H1/5 - Chassis Ground - Located
H1/6 - (+) Door Trigger Input, Zone 3 - ?
H1/7 - (-) Multiplexed Input , Zone 4 - ?
H1/8 - (-) Door Trigger Input, Zone 3 - ?
H1/9 - (-) 200ma Domelight Supervision Output - ?
H1/10 - (-) Remote Start Activation Input - ?
H1/11 - (+),(-) Selectable Light Flash Output - ?
H1/12 (-) 500ma Armed Output - ?
Aux Harness
H2 Harness - I'm pretty sure i can just leave this completely off since there's no factory installed alarm on the xB?
Door Lock Harness
1 Light Blue - (+) Lock (-) Unlock Output - ?
2 Empty
3 Green - (-) Lock (+) Unlock Output - ?
Remote Start Ribbon Harness
1 Pink/White - 200ma Programmable IGN2/ACC2 Relay Turn On - ?
2 Yellow - (+) Ignition Input To Alarm - ?
3 Pink - (-) 200ma Ignition Relay Turn On - ?
4 Orange - (-) 200ma Accessory Relay Turn On - ?
5 Purple - (-) 200ma Starter Relay Turn On - ?
6 Orange/Black - (-) Antigrind/Ground When Armed Output - ?
7 blue - (-) 200ma Status Output - ?
Heavy Gauge Relay Satellite
1 Purple - (+) Starter Output To Starter (Starter Side) - Starter Wire (pin 4 ign plug)
2 Green - Starter Input From Ignition (Key Side) - Switched IGN (pin 6 ign plug)
3 Red - (+) High Current 12v Input - ?
4 Orange - (+) Output To Accessory Circuit - ?
5 Pink - (+) Output To Primary Ignition Circuit - ?
6 Red - (+) (30a) High Current 12v Input - ?
7 Pink/White - (+) Output To Second Ignition Circuit - ?
8 Red/White - (+) (30a) High Current 12v Input - ?
Remote Start Harness
H3/1 - (-) Neutral Safty Switch Input
H3/2 - Tachometer Input Wire - Located
H3/3 - (+) Brake Shutdown Wire - ?
H3/4 - (-) Hood Pinswitch Input - Located
H3/5 - (-) 200ma 2nd Status/Rear Defogger - ?
Horn
H4/1 - Channel 6 Output - ?
H4/2 - (-) 200ma Horn - ?
Primary Harness
H1/4 - Not Used
Aux Harness
Door Lock Harness
2 Empty
Horn
Go to a Shop and get it installed. Seriously, if you have the diagrams and still can't get it, your best bet is to get it installed. My alarm is the only thing on my car that I didn't install. GLWI
Thanks for the advice.
Locating the wires needed on the xB isn't the issue I'm having, i pretty decent with wiring diagrams. I'm just not very familiar with all the wires on the alarm unit. The directions were obviously written for those that are knowledgeable of alarm systems and I'm not. I'm the type of person that enjoys learning new things, while maybe not the easiest or cheapest way of doing it... i did it myself and that i enjoy. Either way, i was just hoping i could come here and maybe someone that was already knowledgeable with alarms and the xB could quickly tell me which wires aren't even used on the xB and what wires should be tapped etc. I don't need someone to go in depth detail on wire locations etc... just need to know what they should tap in to. (ex. XX wire taps in to dome light wire and so on).
THIS THREAD CAN BE CLOSED, I GOT IT FIGURED OUT NOW
I'm assuming you don't have an actual diagram from DEI for the xb. Honestly this is one of the easiest cars to put an alarm and remote start in. Here is link to the diagram.
http://www.the12volt.com/installbay/....asp~TID~80310
TheRedBox
31
Dec 2, 2003 04:53 PM
