double DIN receivers.
is anyone here using a double DIN receiver in his or her scion? is the stock scion receiver even a double DIN size??
if anyone actually has a double DIN one installed, pictures would be nice. :)
I don't own an xA but if the radio si the same as in the xB then it is a little bigger then a double din. You can mount it in using the factory brackets and it will fill in the radio opening from top to bottom but you will have some gaps on the sides that you will need to fix with some ABS plastic or something.
mischman
Sep 15, 2015 03:38 PM
JZA70
Sep 12, 2015 09:44 PM
