An Easy Mod...Changing Climate Controls to LED, No Soldering..
Thanks to Liesjemt @ Clubxb.com
D'ya see where my screw driver is? That's the best place to tug!
The one from autolumination.com is on the right.... the stock xB one is on the left...
Finished!
__________________
Finished!
__________________
check this post, I believe it is the same author and this guy made it easy for everyone. Make sure to read the whole thread.
http://www.clubxb.com/forums/f19/424...d-no-soldering
Hey, autolumination.com is a non-functioning link! i tried three or four times times to get to there web page. No luck! while searching I read what a few guys on the RX8club site. Autolumination gets some very low reviews from people that have bought from them. I guess, be careful when dealing with Autolumination, that is if you can get to their site!
Thanks for the great explantion on this mod. I can't wait to do my re-lamping to LED. Now to find a quality supplier. Any ideas?
I've seen a lot of ways to remove the center panel after the ***** and two screws are removed. I would NOT use a screw driver to pry under the edge of the housing. You could damage the plastic, and that could be a bummer! Here's how I get the panel cover off.
1. Simple put your left and right index fingers in each air-conditioning vent opening.
2. Give it a slight but firm tug. Once un-snaped, slide your fingers down the front of the panel.
3. Grab the panel with your fingers and thumbs and with a firm tug, pull. The lower mounts will pop out.
4. Lift up the lower part of the panel and it will clear the two upper most retaining barbs.
I've done this about 10 times and it works great!
I had no problems at all getting my LEDs in. I have done both methods outlined in the ClubxB.com link. You can go either way but the autolumination link saves about half an hour. try the link on the clubxb website. I live in Maryland and ordered on a thursday I got the LED's on a tues the following link. Granted the first place I ordered from was much more proffessional looking but I have not had any problems.
Neo - Wedge Instrument Panel Bulbs are 10mm (3/8") diameter x 13mm (1/2") high
Blue Super White Red Amber Green UV
Order Neo Wedge Based LED Bulbs (shown above):
$2.99 ea.
Choose Color
Choose Lens
http://autolumination.com/74.htm
so yeah, super freakin' easy!
A little clarification. The original write up on clubxB is mine (and I’m not a guy
). Here’s the link: http://www.clubxb.com/forums/f19/424...-no-soldering/
Salteen, I give more detail on exactly how to do the swap there.
I say we’ve come full circle since my write up is based on a great one by xBassist in the tech section here on ScionLife. And now others are finding ways to improve mine. ‘Gotta love this mod culture.
Now, everyone together, “No more ugly amber lights!”
woah, you're not a guy!?!
“Some medium or fine grade sandpaper. (Or a nailfile for you other girls. Works great)”
I really should update my avatar. :D
There’s not as much room for ‘pics in the profiles here, check the other site. No one would mistake my box for stock! (Or me for a guy.)
Hey liesjemt , great work on that original write up! I checked it out and I did like how much brighter and spread out your end result seemed to get over the initial one pictured in this thread, so I think if I do this, I'm going to try the best of both worlds if possible. Do the easy replacement but file some of the bulb to make the light more even like you said. I don't know anything about modifying cars really, but I can read directions. It's great to other women being so hands on with the mods, keep up the good work! P.S. a bit off topic, but how'd you get your engine cover to look like a polished chrome? PM me if you'd like.
Originally Posted by mad-sciontist
I just used gel covers for mine... Took off the stock yellow ones and slipped on green ones.
