Few Questions about Dynamat
What should I dynamat on my xB? Is there anything I can do for my windows cause the small rear ones that are in between the back windows and trunk windows are starting to become loose. Also, does anyone know people or a shop with good prices? Thanks.
Dynamat it yourself, but don't use actual Dynamat. eDead and FatMat are both great, and soooooo much cheaper. I recommend doors, hatch, floor, wheelwells.
Do it yourself, there are several threads on it, do some searching.
eDead VS1E works wonders. 70sqft should be enough for your hatch, doors, rear quarter panels, and rear floor.
try coupling that with some real sound absorption material like jute and you're in business.
Jute isn't a deadener, it's actually a wave diffuser, but I digress. I posted a thread on her some time ago that gave you a budget install that works as well as the overpriced dynamat, if not better. Deadening isn't about brand name, as all of the rolled tar is made at one of two places, it's about mass loading. You want to keep the resonance and rattle at a minimum.
I wouldn't put roofing tar in my car, but here's Ricochet's post for those interested:
https://www.scionlife.com/forums/viewtopic.php?t=60459
Anyway, just thought I'd throw it out there for those that didn't want to spend a forutne on sound deadener, but wanted the same effect, as it's the same material.
For those on a tight budget, enjoy, I was just saying I wouldn't use the stuff.
Originally Posted by jaydub
McMaster-Carr sells the same stuff that Dynamat uses without their logo. Most people I've seen on car audio forums have found alternatives to dynamat because it is readily available elsewhere.
CLICK HERE
Item number 9709T26?
Also, no one said alternatives aren't readily available.
Good find with McMaster. It is sound dampening stuff. Roofing tar, however, is not.
CLICK HERE
Fatmat is the exact same thing. Dynamat makes it, again, same tar factory as the rest of it. It's identical to Dynamat extreme minus the logo. And they include a roller, cleaning solution, and utility knife.
And yes, I promise you, it's the exact same stuff without the backing. The dynamat doesn't have as bad a smell sometimes. I've smelt some that smells awful. Just depends on the run of tar they use.
bootlgr
Jan 26, 2016 01:22 AM
