foglight question
Old Jan 9, 2004 | 02:27 AM
fliggah's Avatar
Default foglight question
I'm trying to see if I'd be able to put other type of foglights so I'd like to know how do you take the temporary plastic filler out....
Old Feb 3, 2005 | 01:42 PM
Tamago's Avatar
xA? xB? if it's the xA, just grab onto the plastic cover with pliars and pull!
Old Feb 4, 2005 | 04:47 PM
Cockpit_XB's Avatar
Admin Emeritus
For the XB you might have to lift the car up & pop it out from behind im thinking, if not try using a falthead screw driver to pop that sucker out.
Old Feb 4, 2005 | 04:54 PM
ILLER__'s Avatar
just get on the floor and push out them from behind the bumper...
Old Feb 4, 2005 | 05:21 PM
Fridion's Avatar
Yes there are two tabs, one on each side. Push them towards the center slightly and there you go...
Old Feb 4, 2005 | 06:17 PM
peterbilt's Avatar
yep. what he said.
i just added aftermarket fogs to the lower valance this week. got the Lowes OEM switch, split lex tubing for the wires, rectangular fogs to match the headlights... bing bang boom the asian girlfriend looks even better now.
Old Feb 7, 2005 | 05:48 AM
ProjectD's Avatar
^^^^^ how did you wire it exactly, I have fogs that I want to put in my car but I have no idea on how to wire it up.
Old Feb 7, 2005 | 01:22 PM
peterbilt's Avatar
the kit i bought came w/ wiring. so i went w/ it. punched thru the big rubber gromet on the firewall at the drivers side (there's a big bundle of wires that go thru there). ran the wires behind the dash and up thru one of the knock outs. flex tubed everything - i mean everything - right down to the lights.
it really was easy. if you don't have a wire kit, it's just a hot, neutral and a ground. i think the wiring was 14G - perhaps 12G, about 10 feet of it.
hope that helps.
Old Feb 7, 2005 | 02:12 PM
8BALL's Avatar
Wally-World has fog light wiring kits. It comes with a relay, switch and all of the wire you need.
Old Feb 7, 2005 | 02:30 PM
Joehnn's Avatar
You dont have to lift up the xB and you don't have to use a screw driver. lay on the ground reach behind and undo tabs. Takes less than a minute.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
