HELP ! ! !
I removed the system i had installed in my car so that i can rebuild it. trust me it was a mess or else i would have left it. the problem is that now in the process of rebuilding it, i have no time to work consistently on it, but for some reason i dont get any sound now. my radio turns on but no sound??? PLEASE HELP !!! I NEED MUSIC...
Umm, could you be a little more specific? What exactly did you remove? The stereo, speakers, sub, amps, all of the above? If you're running an amp to your speakers, double-check all fuses and grounds.
Check your inline fuse(s) and check the fuses in the car. Check your ground(s). Check the remote wire (make sure it is free of cuts, nicks, breakages in the wire, connected to the amp, etc). Check your speaker connections. Check every component of the system /install.
One thing to note here, when working around the dash, disconnect the battery. If you are only working on the dome light or tail lights it may not be that critical, but in the dash is it necessary.
As riccochetrabbit suggests, check your fuses. Hopefully it is as simple as this.
