Help with gauge cluster
Old Dec 31, 2005 | 02:19 AM
DuxwhiteXB's Avatar
Default Help with gauge cluster
While installing my new Kenwood headunit I noticed that it had two illuminations and one dimmer, while the stock headunit only had oneillumination and one dimmer. So I asked my friend who works at stereo shop(and also owns a scion) which illumination to hookup. So i hooked the one he said, and it ended up being the wrong one, so when turned the ignition on to tested it out. I noticedthat the gauge lights were not on when i turned the lights on. (it burnt out the four leds that light up the speedometer). all the other lights work except the four for the speedometerand i know there is power because i tested the wires on the entire cluster with my multimeter. So i need to know if it is hard to replace the leds, or can i get the gauge cluster from a junkyard or do I have buy a new one. So please can some one help me out because i am tired of driving home late at night from work with no speedometer lights.
Old Jan 2, 2006 | 07:39 PM
DuxwhiteXB's Avatar
bump
Old Jan 2, 2006 | 07:51 PM
NeoXa's Avatar
You might have blown a fuse, i have done that before. Check the fuse box under the mirror controls and illum. etc. there. it blew the fuse before, check the " lights " one
Old Jan 2, 2006 | 09:46 PM
hotbox05's Avatar
it's a fuse. and the leds are fairly easy to change but it is time consuming and a bit of a pain.
Old Jan 2, 2006 | 11:18 PM
DuxwhiteXB's Avatar
I already checked the fuses and fixed them. But after taking the guage gluster apart and tested it I know that the fuses are blown. I just ordered the leds saturday but I am kind of nervous changing the leds because they are small. But i'm pretty good at soldering so i think i can do it. By the way if when i swap out the old leds to the new ones, do I have to change the resistors.
thanx, Josh
Old Jan 3, 2006 | 07:30 PM
cyclotron_burst's Avatar
you shouldnt have to change the resistance unless you are using a different voltage LED. Well that is to say you might want to test the existing resistors to make sure that they are not blown out also.
SloTC1
Aug 16, 2018 02:45 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
brett561tc
Sep 15, 2015 06:33 AM
paisatronix
Sep 5, 2015 04:13 AM
