how do i?
Old Jul 13, 2004 | 06:54 PM
Fujiz_xb's Avatar
sIcKsCiOnS
Default how do i?
how do i remove the cover to remove the radio to install the wire to connect the line converter to connect the rca out for the amp?
simple terms..how do i remove the cover to access the stereo harness?
please let me know..digrams would help, since pictures are more helpful.
Old Jul 13, 2004 | 07:04 PM
ikhonlord's Avatar
If you are talking about removing hte center panel so that you can reach into the back of your radio in an XB....Here it is:
https://www.scionlife.com/forums/viewtopic.php?t=11283
If you check the beginning of this post it will show you how to remove the center console. Presonally instead of using the "pry the bottom" tecnique I decided to pull from the top by applying pressure downward and the pushing the console towards you....Hope this helps!
:D
