HOW DO I BYPASS THE PREAMP????
That's why I always recommend having a pro do the install, unless one is knowledgeable and experienced with *correct* installations.
It is amazing some of the installs I've seen.
Of course not even all the "professional" installers understand how to do things right. (I've even seen a "pro" here on SL recommend just twisting wires together and covering them with electrical tape to make good connections... *sigh* )
^^ such a disgusting thing to do to a car! I have seen a ton of things like this... Its like taking a crap and not whiping to be quite blunt about it
Wires should be soldered and heat shrink covered. Twisted wires are not only weak physical connections but also allow oxidation to occur between strands. I have seen the most of this type of wiring from dealerships installing options... it is scary!
As for your audio issue, it should work if you wire it up to the stock wiring. I would start checking wiring setup.
jallamas
Jul 27, 2005 12:18 PM
riccochetrabbit
15
Jul 21, 2005 01:49 AM
