How to Reset the Factory Radio???
Old Mar 7, 2006 | 02:54 AM
Nikatnite79's Avatar
Default How to Reset the Factory Radio???
Hello..I was wondering if there was a way to Reset the Factory Radio. I hooked up a wire harness to have an amp hooked up to my stock radio.
Well my problem is that after I was done I was listening to my radio and after a few minutes out of nowhere it just shut off.
So I uninstalled the wiring harness and hooked it back the way it was and it still does not want to work. It won't even turn on.
What the hell happened??? thx all
__________________
Old Mar 7, 2006 | 03:24 AM
stick_1NZ's Avatar
Did you cut any wiring when you connected the wire harness???
Moved.
Old Mar 7, 2006 | 05:16 AM
SmokingTires's Avatar
Fuse?
Old Mar 7, 2006 | 09:20 AM
That wire harness was made to not have to cut any wires... It could be a fuse... Witch fuse controls the radio???
Old Mar 7, 2006 | 09:32 AM
Yea I know, I have the same one in my car it works great. I even leave it connected when I take my subwoofer out. The only thing I can think is that you let the signal wire for the amp turn on touch a ground and it blew a fuse for the radio. Which one is it? Look in your manual.
Old Mar 7, 2006 | 12:47 PM
stick_1NZ's Avatar
there's a fuse box right above your kick panel under the dash on the driver's side. the cover just pops out and there is a label that shows which fuse corresponds to. you can also check inside the engine bay, there another fuse box in there with labels. good luck.
Old Mar 7, 2006 | 09:55 PM
I looked all over and none of those fuses are for the radio and I called the dealership and they said they have to pull out the radio to get to the fuse??? does anyone know anything about that????
need4speed
Scion tC 1G ICE & Interior
Nov 26, 2006 06:37 AM
FirstInHell
Oct 15, 2006 05:55 PM
Fuesad
Aug 11, 2006 12:06 PM
bambams247
Mar 19, 2005 05:36 PM
aslugger3b
Feb 6, 2005 05:39 PM
