I'm going to upgrade my speakers and get a sub v.questions
this is a quote from another thread asking about installing a sub and amp with the stock HU.
is this all i need to hook up the sub to the stock HU? will it be able to handle it, including installing new front speakers?
TIA
1 Pioneer or Rockford Fosgate PS1 10 inch woofer (currently the Rockfords are dirt cheap I get them for $42 each) Best Buy
1 prefab box (about $40 squre simple basic sealed)
1 200 watt bridged amp (Currently the small 2 chanel from Pioneer suprized the hell out of me costs about $100) Again best Buy
Couple feet of Amp power wire (about $15) Yep Best Buy
High level converter ($20 or cheaper) Best Buy (no I don't work for them or love the store, it's just a fairly cheap place to get stuff)
TIA
I would say you need the following depending on where you want to mount the amps:
-Line out converter (Which I happen to have a sweet one I'll sell you for less than $20) http://cgi.ebay.com/LOC-Line-Out-Con...QQcmdZViewItem
-Amplifier
-Cabling- Power (Red) 15 to 18', fuse holder/ circuit breaker less than 18" from battery on power lead, Ground (Black) 5', 5/16" Ring terminals, remote turn-on wire (small wire) same length as power wire, RCA cable to amp from deck (ran along opposite side as power cabling) 17', speaker wire 40' 16AWG
-Subwoofer
-Enclosure for sub
-Grommets
-Zip Ties
Mark
EDIT- So you are aware the stock deck doesn't have provisions for a remote turn on lead. You can wire it to the ignition lead but make sure to put a power switch inline so that you can turn off your amps when you want to. Otherwise it's kinda annoying to have the amps on when the car turns on. If you have any other questions please give me a shout.
-Amplifier
-Subwoofer
-Enclosure for sub
-Grommets
-Zip Ties
Mark
-Amplifier
-Subwoofer
-Enclosure for sub
-Grommets
-Zip Ties
Mark
-Amplifier
-Subwoofer
-Enclosure for sub
-Grommets
-Zip Ties
Mark
but do i need all the things that you posted PLUS what i quoted? i'm a little confused
Originally Posted by BloodySunday
mfenske, is this something that i can do by myself without any experience, or should i take it to the shop and get raped?
Check this out!!!! they just sent me my dash and wire kit. Looks very easy
https://www.scionlife.com/forums/viewtopic.php?t=104383
umnitza
Jul 25, 2015 07:54 PM
