Inside of xB front doors...
Those yellow foam pieces on the door panel: What are they for? Do they protrude a lot into the holes in the door? I want to take off the vapor barrier and cover those holes with plexiglass to seal it up and make the door more effective as an enclosure. Will I have to shave them down, and what would happen if I removed them?
Its for noise reduction, believe it or not without that plastic and foam your door sounds like its falling apart and you get a lot of road noise. I think your plexi will provide the same.. might add some rattle.. not sure
The goal would be to take off the vapor barrier, cover the outer door skin with deadener, cover the holes with plexi or wood soaked in fiberglass resin, then put deadening mat all over the inner door skin.
I ask because it looks like the foam wouldn't fit anymore at that point.
There's no need to remove those foam pieces if you sound deaden your doors, just don't pull your deadening material tight in those open areas, push it inward some when installing the material and you'll be good. That's what I did, I'm running 8's in the doors and it seems sturdy enough, only problem area I'm having is getting a good seal along the top edge of the door panel to the window.
hampton1100
May 28, 2015 07:32 AM
TheTripleC
Jan 4, 2015 06:46 PM
