installation help
all i need to do is ask a few questions on how to install a system i got alot of ____ installed just cant get it to work i need to ask a few questions its prolly im doing osmehting wrong if you got aim or yahoo just post it after your reply
ok i instaled my stero system an for somereason the amp gets power with out the ground an my speakers wont work thouhg if you know whats going on help me out on that one an if i do need to ground fit later in life where would i ground i to cause my amp is under the seat an i was thinkin about grounding it to the seat bult but the bult is to big
You could bolt it to the seat bolt but idealy you want to ground it to the body somewhere. What you could do is cut a little flap in the carpet under the seat and just screw it into the floor. Mine is bolted through the floor but for your setup I would recomend just screwing it to the floor this should work if it doesnt scuff up the paint a bit with some sand paper so the ground connector is metal on metal.
Steve
Steve
Originally Posted by Soto
ok i got that but when it touches metal my amp doesnt have power when i take the ground off metal it has power its the weirdest thing you know anything about that?
USE PUNCTUATION
Becareful to not keep lifting the ground for the amp like you are doing. There is a good chance that it will surge and the ground feed will feed through your RCA cables and blowout your head unit..
I could barely understand your post, so my best suggestion is to check all your wiring. Who cares when you lift the ground the amp turns on. That means your getting some type of feedback that you dont want.
TheRedBox
31
Dec 2, 2003 04:53 PM
