Just installed 6.5" speakers in the rear
Hey, i was just curious, how come you have to use the box and not the other inputs for it to work?
Originally Posted by cyclotron_burst
...There are alot of Dynamat and Second skin knock-offs that dont do anything more than weigh down your car...
That's all sound dampening material does. Adding weight is the best proven method for fixing rattles because the extra weight changes the frequency in which the panel or piece resonates or vibrates....
But in the original post, it says the amp has High Level(speaker level) inputs which should eliminate the need for a line output converter....
Originally Posted by Spr0ket
Even the guy who patented the product on the first caps won't use them.
Maybe you can cite some sources so I could research this one myself.
Last I heard, low ESR electrolytic caps still work exactly the way they were originally intended, as large energy storage reservoirs that can supply incredibly quick bursts of energy to your amplifier with the potential of increasing the power output supplied from your amp to the speakers for a very short time. Not to fix dimming lights, that has more to do with how tightly the the voltage is regulated to them. They work because your amplifier is going to draw from the source with the highest potential, the low ESR cap first til it's depleted(never would deplete entirely, only down to the level that the rest of the system is at), then your alternator til it can't supply enough voltage for the system, and then lastly the battery till its depleted. The only thing that has changed over the years is the cap marketing and engineers that can prove that the sky isn't really blue.
http://www.carstereo.com/forum/showt...id=25962&fid=4
Most interesting to me was "How much power does a capacitor store".
Stock fronts are 6-1/2". Some say 6-3/4 or "oversize 6-1/2". but they measure 6-1/2" across the front/foam ring. I just measured the ones I yanked for my eDi 6000 install.
As a reference, the eDi 6000, with a mount depth of 2.8" needed (2) rings of 3/4" mdf to clear the window. It gives about 1/4"~3/8" clearance and still fits behind the stock (slightly modded) door panel. This will give a baseline to add/subtract for your own mids.
My xB eDi6000 install:
https://www.scionlife.com/forums/vie...789&highlight=
jaimecosio,
No increase in SQ? Your Memphis need more power than the stock HU amps can supply!
jaimecosio,
Scroll down to the reply from SteamHammer...
He never addresses low ESR caps, which are the ONLY ones to get if you want a cap to work as was intended for car audio. Try and find one that has a ESR that is <.001or better(Example: <.002 is worse and <.0001 would be better). Most manufacturers don't advertise the ESR spec. Happy Hunting!! :D
It is true that many of the caps out there simply won't work as expected because of a too high ESR. But they certainly do look cool, and in that situation you might as well get the extra battery. But then you have a different situation where your alternator has to charge two batteries. Typically adding another battery consumes about 5-10 amps of precious alternator juice, meaning less amperage for your amplifier.
Heres Richard Clarks(Yeah, one of the guys who marketed large caps for car audio use) own forum talking about this.
http://www.carsound.com/UBB/ultimate...1;t=022965;p=1
I just put 6.5's in the rear of my xB. All I did was use the scoche brackets made for the front and three self tapping screws to hold the brackets to the metal....clears everything nicely and fire directly through the grill in the panels.
clickclickw00t
02-18-2015 08:57 PM
TheRedBox
31
12-02-2003 04:53 PM
