Kenwood DVD install question?????!!!
Old Jan 28, 2005 | 12:35 AM
LowProMofo's Avatar
Default Kenwood DVD install question?????!!!
I'm trying to hook up the Kenwood DDX 7015. ON the little connector where you hook up the E-Brake how do I go about going around this. Also do I just connect the power wire from that connector to the fuse box? I need some answers fast guys!
Thanks!
Old Jan 28, 2005 | 12:47 AM
dgHotLava's Avatar
that wire needs to be grounded when the parking brake is applied.
this stops the dvd from playing while the car is in motion...(you would not drive with the e-brake up. right??)
just ground this wire to defeat this...
try searching for more threads like this...
Old Jan 28, 2005 | 12:49 AM
dgHotLava's Avatar
the power wire should be connected to the factory harness (you did get the wire harness for the car right??? no cutting of wires right???)
Old Jan 28, 2005 | 12:56 AM
LowProMofo's Avatar
So the yellow power wire needs to connect to the wiring harness' yellow power wire?
Old Jan 28, 2005 | 01:00 AM
LowProMofo's Avatar
Yeah I have the harness, no cutting, so I just connect the yellow wire from the other plug to the yellow power wire?
Old Jan 28, 2005 | 01:02 AM
dgHotLava's Avatar
correct, you really just match up the colors...
and connect the power antenna wire too.
Old Jan 28, 2005 | 01:03 AM
LowProMofo's Avatar
BTW Where's a good place to ground those other wires?
Old Jan 28, 2005 | 01:07 AM
dgHotLava's Avatar
to the harness. everything should go to the harness...
Old Jan 28, 2005 | 01:11 AM
LowProMofo's Avatar
Yeah I have the harness wired together but there is another plug on the back of the HU with another power wire, ground and the E-Brake ground. Do I connect the ground on that one to the harness and the power wire?
Old Jan 28, 2005 | 01:15 AM
dgHotLava's Avatar
yes, all grounds to the one in the harness.
all power (yellows) to the one from the harness....
there is only one power ant wire. the other is the remote turn on for other electric devices (amps, head rest tv's, back up camera......)
Old Jan 28, 2005 | 01:17 AM
LowProMofo's Avatar
Thanks man!! You've been a big help! I'll post some pics when I'm done!
Old Jan 28, 2005 | 01:28 AM
dgHotLava's Avatar
cool....
Old Jan 28, 2005 | 01:40 AM
LowProMofo's Avatar
Last question man! Can I connect the green e-brake ground with the other black grounds?
Old Jan 28, 2005 | 01:49 AM
Jdawg82's Avatar
Yes you can connect it with all the other grounds. I just installed this deck in my buddies saab looks factory.
Old Jan 28, 2005 | 03:24 AM
LowProMofo's Avatar
Thanks for all the help guys! Here's the install. I'm going to clean evrything up and take some pics of it tomorow hopefully. I also still have to get the 2 spacers for the sides. Anyone wouldn't happen to know a part number on that would they?
Old Jul 13, 2005 | 02:24 AM
djhax's Avatar
Does anyone know where I can get "just" the installation kit(harness) for this unit for my tC
Old Jul 13, 2005 | 02:29 AM
freeflowing's Avatar
looks good but i think you can bypass the ground and play dvds while driving. i dont advise this though
Old Jul 13, 2005 | 02:32 AM
LowProMofo's Avatar
I did do that. And this was posted in Jan!! I don't even own that xB anymore! LOL
Old Jul 13, 2005 | 02:37 AM
oh really what do you own now???im to lazy to read profiles these dayz
Old Jul 13, 2005 | 02:41 AM
LowProMofo's Avatar
Yeah I got rid of it about 2 months ago. I needed something bigger and more room.
Check it out here:
https://www.scionlife.com/forums/viewtopic.php?t=66802
