LED help.
Ok......so I got all my cathodes and such hooked up and working. But....I'm having trouble with the LEDs for the cupholders. They say their 12v, and supposed to be able to handle 12-14v.............but, when I had them all set up......I turned them on........and they were on for a few minutes, then they burned up and melted.
Any help here? Thanks.
KiL
KiL
what type of led did you get? cause most leds that i use is 3volts. are you talking about a bare led or leds with resistors already hooked up with it ..
lick me:..
Hubert
Hubert
I'm using this:
http://www.mge-usa.com/home/detail.a...193&iType=802#
It might have a little resistor in that housing somewhere. Its made for computers. Computers are 12v right?
KiL
KiL
yes pc stuff are 12v but one thing that im not sure with that led setup is that if it can handle upto 14v(which an alternator pushes out when the engine is on). the way i did mine was i used a resistor for a 14v setup and not a 12v on my leds. or you may have just gotten a defective set.
hubert
hubert
Yeah computer stuff is 12 volts but stays at 12volts. It dosent raise and lower constantly like in an automobile. You can get as high as 15 volts at times in a car and burn them up. The ones CRxB showed you would be better suited for your application.
SJMiller
Sep 12, 2015 06:33 PM
