an led placement where nobody thought of putting one at!!!
pictures says it all!!!
i always thought there should of been an led here so i did
it needed it too!!!
anyways on to the pictures!!!
and now i know where the freash air/recirculate door is at now :D
it needed it too!!!
heres a quick write up
after you got the face plate and the switches unpluged off... pop off the two taps on the side to free the (the name of it is in the picture haha)
i used a flat blade screw driver to press it down and it slides right off with (pull gently it will come off)
you need to also take out the metal bracket there it just pops right out when you disengage the claw on it... to better get the drill bit in there
use a drill bit slightly smaller diameter then the led (around a 1mm smaller) and drill and if it needs to be bigger file out the hole with a round file or just use the drill bit to make it a little bit bigger
and press in the LED... tight fit...
your gonna want to paint the back of the LED as you can tell from my post above this one kind of bright back there
pull the wires thru this hole leave enough slack for the movement of the switch... (thats a must, duh haha)
when putting the lever back on make sure the metal tap is on the bottom (as you see in the picture
i wired it too my headlight and dimmer switch wiring
cid_mcdp
01-05-2015 02:45 PM
TheTripleC
01-04-2015 06:46 PM
spawnconnery
12-18-2014 08:38 PM
