Line Out Converter Crap For Components
Old Jan 8, 2005 | 08:18 PM
ChefRaekwon's Avatar
Default Line Out Converter Crap For Components
Well I have had numerous CD Decks in my tC. Unfortunately there all Single Din which sucks because it looks like ___ and I still do not have a stereo kit for it yet. Well right now I have a Nak 35z in my tC running yo my SS Van Gogh amps and thought of trying to use the factory Pioneer deck because I wanted the stock look. Well it didn't work. I purchased a Line Out Converter and Toyota Reverse Harness from both Best Buy and Circuit City(bought different brands to see if one was better than the other). Hooked it up and its horrible. The amount of engine whine, radio static and the amp pops when u first turn on the ignition. I was hoping I would have better luck because I really wanted the factory unit but it didn't work. Just trying to save people time and money by giving my opinion. For people that use the line out converter for subs only it probably works fine, but for components in the front or rear the speakers produce every little noise in the system. I am not new to this so I do know how to hook it up in case anyone was wondering.
Hopefully some quallity companies come out with a double din cd player and not an in dash TV(I'm poor).
Old Jan 9, 2005 | 01:00 AM
tbone587's Avatar
there are already double din cd players available, made by pioneer for example which is pretty decent..
Old Jan 9, 2005 | 04:42 PM
VtScionGuy's Avatar
Actually, one thing I was going to do but got lazy was to put the single din cd player into the storage bin. And leave the factory radio where it was.
Old Jan 10, 2005 | 04:52 AM
johnnyicesae's Avatar
why not get one of those feature rich double din units that are only sold in japan and get a frequency converter to use to get american radio? Wouldn't that kill 2 birds with one stone?
Old Jan 11, 2005 | 07:07 PM
JLTD's Avatar
Default Re: Line Out Converter Crap For Components
The LOC's are part of the problem. Unless you spend big $$ on them, you are dealing with some cheap transformers that are no that great for audio applications. If your amplifier has differential inputs, you could splice audio cables right to the radio speaker level output. If you amp takes high level in, use that (which is what I did). Both of these will work out better than LOCs in many cases.
The other problem you are dealing with is the dreaded DSP eq curves built into most OEM head units now. DSP has become so cheap that it's more cost-effective to build in eq curves that compensate for the limited performance of the $1 speakers they put in cars. When you add aftermarket products the EQ and the speakers don't match so the sound is less than you'd expect. With SCION, it not really a big deal to switch the radio, but in many cars, it's not an option.
I installed a system in my TC using the OEM deck. I am having issues with the DSP and how bad it sounds with my new speakers (especially with SIRIUS). I don't want to add an aftermarket radio because so few of them are actually upgrades and the often look "funky". One possible solution to the problem is to add a 30 band EQ to the outputs. After I analyze the outputs, with an RTA I could make corrections by doing the opposite of the OEM curve. This would send a flat signal to my amps. There are two problems that remain:
Much of the EQ is volume dependant (low frequency attenuates when volume increases)
Each channel has it's own curve (I would need four 30 band EQ's).
Although I have no noise problems, I am waiting for a solution that is coming soon to make it sound better.
http://www.jlaudio.com/press/CleanSweep05.html
k1114
43
Mar 1, 2023 03:08 AM
nightfox915
Apr 17, 2015 07:06 PM
ScionLife Editor
Apr 16, 2015 07:10 PM
corbmonster
Jan 24, 2015 06:13 PM
NYXbScion
Feb 24, 2004 08:13 PM
