Mounting Depth in the doors for an XB?
Originally Posted by SCI_TC_GUY
don't worry about mounting depth.....just make a spacer out of MDF......solved.....
HAHAHA.......that was good fuji........
any 6.5" mid that you would get in a component set will fit with a 3/4" MDF spacer........
if it doesn't: then the speaker doesn't need to be in the door...it needs to be in a kick panel with a certain amt of air space....
Originally Posted by Big Boy Phil
Just a thought. Does anyone know if it's possible to mount speakers in the back passanger doors of the XB? How about mounting some 6x9's in the rear hatch/door of the XB?
you are not really trimming the door panel itself, there isa ring that I guess holds the grill rigid, but with almost any speaker other than stock you will need to trim down to get the door panel to snap back on at the bottom.
When you see the inside of the door panel you will see.
It is not a major issue.
I wish I took pics of it when I had the door apart 2 weeks ago.
SpaceCaptain
May 11, 2015 06:24 PM
HotLavaDestiny
Feb 8, 2015 05:25 AM
squirrel
Jan 5, 2004 01:31 AM
