need help install neon.
Old Feb 14, 2007 | 02:00 AM
flappysausages's Avatar
Default need help install neon.
i just recieved pilot neon lights for my scion, it says that it hardwires to my scions 12 volt easy source, where exactly would that be?
Old Feb 14, 2007 | 02:05 AM
SquallLHeart's Avatar
pretty much anywhere in the car....?
cig lighter is a spot? battery too?
Old Feb 14, 2007 | 02:30 AM
here is what the wires look like, i would like them to be under the dash, so where would i install them?
http://www.imagemule.com/uploads/img00073lFo4.jpg
Old Feb 14, 2007 | 03:34 AM
TerribleTed's Avatar
Too a switch so you can turn them on and off . Wire from a + DC source be it battery, lighter, fuse block whatever to an inline fuse to the switch (one you are going to purchase and install) and then from the switch to the +wire of the neon unit. Wire the other side of the neon unit to ground. If from this description you need further help I would suggest a professional installer.
Old Feb 14, 2007 | 05:53 AM
cherryBox's Avatar
Default Re: need help install neon.
honestly, electrical can be tricky if you don't know what you're doing. consider having them installed at a stereo shop.
Old Feb 14, 2007 | 05:56 AM
guitarguru44's Avatar
Yea, what terriblted said.
There is a positive and negative cable off of the neon. If you touch these to the battery they should light up.
Connect the negative (black) to anything that is metal (a screw for example) and connect the positive to a switch like he said.
SuBSiN
Mar 13, 2015 04:02 AM
randomsuper
Feb 27, 2015 01:29 AM
Frustratez
Feb 26, 2015 04:03 PM
ofgarcia
Dec 22, 2014 12:27 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
