Need Help ! Removing Headlights <XB>
Old Sep 3, 2004 | 11:44 AM
House_Of_Steel's Avatar
Default Need Help ! Removing Headlights <XB>
I tried doing a search and nothing relating to removing the headlights appeared, just a bunch of other stuff ......
NEED HELP REMOVING THE HEADLIGHTS ....
Here is where I am with this, I removed to the top 2 screws and that black push doen screw pin attached to the grille ( Hot Lava ) - I called my dealer and ran over and got a spec sheet that shows 2 more scres or something holding the assembly in, I can't see the other 2 screws or whatever ?
Does anyone have any tips ?
Also - How do the fog lights come out, do they just pop out, tried that and it seems something is holding them in ?
Thanks Folks ...
Old Sep 3, 2004 | 12:01 PM
TheIcon's Avatar
As far as the fog lights. If you get your head under the bumper with a flash like there are 2 clips. If you pop the one it pops right off. REAL simple once you get your head under the bumper to see exactly how it is put on.
In one of these pictures you can see how he reached under the bumper to undo the one clip and he used his other hand to pop it out. http://overboost.com/print.asp?id=1098
As for the headlights. This might help. Im not sure
https://www.scionlife.com/forums/vie...=clear+corners
Old Sep 3, 2004 | 12:15 PM
WFO's Avatar
WFO
N.G.S.O.
Default headlight
to get the headlights out of the xb you have to take off the whole front bumper cover
there are about 6 screws under the front one on each side at the fender and a couple under the grill that you have to take out this is crazy way to build a car
Old Sep 3, 2004 | 12:17 PM
WFO's Avatar
WFO
N.G.S.O.
Default here
look here
you will need a pick tool if you want to make this easy
Old Sep 3, 2004 | 12:22 PM
TheIcon's Avatar
Default Re: here
Originally Posted by WFO
look here
Got to it before you
Old Sep 3, 2004 | 12:26 PM
Default Thanks ...
CHIT ...... Looks like the fogs should be simple, the headlights look tough !
Not going to be an easy task to remove them .....
Old Sep 3, 2004 | 03:24 PM
JDMJim's Avatar
yeah, the whole bumper comes off but takes only a few mins with the right tools. While your in there, might as well change out the horns for something louder. Thats how I know about the lights.
Old Sep 3, 2004 | 05:20 PM
superjeer's Avatar
I thought I had to get the headlights out to remove the facia.. but it turned out to be the otherway around.. the headlights never did come out (thank goodness, since they didn't actually need to).. I was replacing my lower grills.. Which, HOUSE, I'm betting you're doing? If "yes" then you needn't remove the headlights. You just need to be firm but carefull to get that tab out to remove the facia.
carid
Apr 7, 2015 02:21 PM
scsteven
Jan 25, 2015 01:06 AM
Itsdchz
Jun 30, 2009 04:54 AM
BCS
Oct 12, 2003 09:52 PM
