Need Help with Stereo install
Hey all,
So I just installed a new pioneer headunit, two 10 in subs and a mono amp. the amp is connected to the rear rca outputs of the hu. I now find that the rear speakers are not working any longer. Is it because the amp is connect to the rear outputs of the hu bypasses the output to the rear speakers. Thanks
All the connections are made on the wiring harness, so yes the rear speakers are hooked up. The amp is connected to the rear rca outputs. I was wonder if connecting the rear rca ouputs to the amp would bypass the rear speaker connection through the wiring harness.
Have you tried pulling the RCA's and hooking them up to the front output to see if you get the same result that way? If you pull the RCA's and leave them off all together do you have all the speakers working except the sub?
In my other car I have a Kenwood hu hooked up the same way and no problem. I have never had a hu do that, but then again I haven't had every type of hu.
wiltonhall
Jun 23, 2025 10:09 PM
reagan9000
Jan 28, 2015 06:20 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
