Need opinions on subs and electrical set up....
Well I WILL get a scion this summer since parents were going to buy a 4wd car for themselves (but I didnt need it so the keep the baja)
Anyways......
I was wondering what would sound the better (quality and enough bass to make my mirror shake) I was either looking at the jl audio 12w3v2 subs (x3) or Kicker Solo-Baric L5 02S15L5 (pretty sure 3 15 inchers should fit). I got some questions though
Should I get 2 ohm or 4 ohm subs? Whats the difference?
Can I hook up an amp to the stock pioneer head unit? If not I already have a Pioneer DEH-P850MP head unit.
What type of amp should I buy to power these suckers up? Also how do I go about connecting three subs with one amp? I only have 1 sub drive on MY pioneer head unit, but also have 3 RCA jacks, but I have been told to use the direct sub drive.
What type of speakers and amp set up should I use to replace the stock speakers in the car. I am probably going to use 2 amps.
Anyways......
DelMarVa
Scion Tuners
Scion Tuners
We have 2 12" MTX sledgehammers in our Box and it is overkill. 3 12" or 3 15" is more than just Mirror shake
. Our system makes the roof bulge over an inch running off the stock head unit (yes you can run it off the stock one) to a 5 farad cap into a MTX 202 which boosts the signal to the 1501 running @ i believe 1 ohm.
With our roof bulging at 45 on the stock head unit I would cringe to think what 3 15s would do. Besides what Amp is going to run 3 15 inch Kickers? I would think you would need at least 3 600 watt amps for that set up, but I sell cars not install stereos.
After fine tuning our system hit 141 SPL at the dashboard at 60 on Feel. Aftermarket headunit makes a huge difference by the ability to better fine tune and control your bass.
Anyways......
Anyways......
If you do it right, you will be amazed, as will others.
A w7 would defenitely get the house rocking, 'specially with 1000w rms to a 12. My PG Ti 10's will be getting 'bout 300 rms and they will rock.
Mike R.
rolex87
Mike R.
rolex87
I have these 2 MOMO 12s with one MTXThunder801D and you can hear my xB rattle like crazy not much of a rattle than a thoing sound from the side panels. Metal so thin that you can see it flex side to side as the bass hits. HAHAHA greenbean and I were acutally comparing the noise outside our cars with the door closed last sunday...ofcors greenbean has a wall of 4 12s in his camo xB.
I'm acutally in the process of adding 100 feet of deadener in the entire cab so watch out for my DIY post soon.
Hubert
Originally Posted by scionxb04
i plan on doing 3 15's in a slot loaded box.....for those of us wanting to put up decent spl numbers
i have 2 elemental design e12a's running off 2000 watts rms and trust me, u do not want to sit in my backseat when i am bumping. absolutely overkill bass, but thats what i like. just got it metered last weekend, 146.3 on the new audiocontrol mic. not bad for being tuned to 30 hz and no sound deadener yet.
ok I see your point, so I probly will be running my pioneer head unit with 2 1,000 watt 15 inch kickers powered by a 2 1,000 watt amps (I bet there is a thing out there to get both amps hooked up the the 1 sub drive)
Originally Posted by urban_assault_XB
I have 3 10" right now so thats equal to 2 15" but I gonna redo it with fiber glass when I have time and then I probally run 4-6 10" mainly for looks
How are you guys putting out all that wattage on factory battery and alternator or do you have after market. I want a bigger alternator but don't know whereto look. any help appreciated
well anything over 1200 watts rms and the stock electrical starts to lose dip greatly in voltage. i have a yellow top up front and one in the back as well as the magic 3 and my voltage doesn't drop below 14.0 volts with about 2000 watts rms. it also depends on the effieciency of the amps as well. but a ho alternator would also be a good choice in upgrading your electrical system.
I got my Xb in the shop right now. I'm getting 4-10" USD subs put in a sealed box (partial plexiglass with 20 red LEDs inside). CDT's on all four doors and imaging tweeters on A pillars. Alpine headunit, 5.1 processor, and Digital EQ. I'm using Crossfire amps (2000 watts for subs, 800 watts for highs and mids). I'll have a bigger alternater and two yellow top Optima batteries, one in the engine compartment, and one in a custom built enclosure under the rear frame. I'm planning on competing for SQ and should be able to hit some respectable SPL levels along the lines of 145-150db (hopefully). I am the only Scion Xb registered in IASCA.
My 10's are getting between 300-325 watts rms and they make my hair shake enough. I'm competeing for sound quality in my area, but these babies get plenty loud for me! But quality of install is most important for me!
Mike R.
rolex87
Mike R.
rolex87
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
Scionxa180
Feb 17, 2015 05:35 PM
yamahamx117
Scion xD Suspension & Handling
Dec 25, 2014 01:54 PM
