Neon on xb questions!!!!
Old Jan 18, 2005 | 05:39 PM
oni424's Avatar
Default Neon on xb questions!!!!
I got two 15 inch neon tubes i am installing in my box. i have them wired and the perfect place for the passanger side, but i need to find out where the dealers are installing the driver side. Ps. WHat size are dealers putting in?
Pics would be helpful.
Old Jan 18, 2005 | 06:13 PM
kacosta's Avatar
what i did with my kit (and i work at the dealer) is to wire
tie them in the factory kit provides these cheezy brackets
just find a spot on the drivers side there will be enuff brackets you can just wire tie them to left to right and i
do think 15 inch is the size of the factory tubes now for the
rear seats lift up the lower flap on the seat back and wire tie
the tubes to the seats hog rings under the flap neat easy
and quick btw the front wire tie trick only works on xb on the
other models you have to use the brackets or go aftermarket
Old Jan 18, 2005 | 07:36 PM
TheScionicMan's Avatar
ha, I thought I was the only one to put the rears under that flap... it works so much better there.
Old Jan 19, 2005 | 01:06 AM
oni424's Avatar
How did you wire the lights in? I used a switch, ran the power from the cig lighter, but had to find another ground? Where did you wire the power from?
Old Jan 19, 2005 | 01:17 AM
JDMbB's Avatar
i used to have mine powered from the cig lighter and used the same ground from the cig lighter. but then i wired it to the fuse box using an Add-A-Circuit so i can turn them on whenever i want. but i still kept it grounded with the cig lighter ground.
Old Jan 19, 2005 | 11:09 AM
hotbox05's Avatar
wow i put my neon tubes in those flaps too!!
Old Jan 19, 2005 | 02:08 PM
Da_BoX's Avatar
you should ask Max2k hed probly know
Old Jan 19, 2005 | 06:05 PM
dgHotLava's Avatar
moved...
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
