new goodies for the B
I've got some goodies this weekend for my B. first I ordered a night vision backup camera off of Ebay and installed it, with a little help from a Unibit to widen the wiper hole, and Dave wondering what he got himself into (we did his xB the same way):
[img]https://img.photobucket.com/albums/v...monitor001.jpg[/img] then I made a monitor mount where the rear view mirror was, wrapped in black suede to match the headliner, painted the monitor trim blue to match other things in the xB, and installed the monitor. I plan on walling off the back so a rear view mirror will be useless: [img]https://img.photobucket.com/albums/v...monitor005.jpg[/img] it is really cool at night. you hit the brakes or go into reverse and you see fine. It's really freaky when you drive and see the road go by. this is one of the coolest and sweetest mods yet. |
That's cool...but where is your mirror?
I got rid of it. this is taking the place of the mirror.
very clean install but seems like you would have problems with the local police officials.
Holy orange peel, Batman!
I think it's just the lens of the camera causing the orange peel effect. At least I hope so! He'll let us know for sure once he reads this.
In CA at least, a rearview mirror is not required if you have sideviews on both sides.
26709. (a) Every motor vehicle registered in a foreign jurisdiction and every motorcycle subject to registration in this state shall be equipped with a mirror so located as to reflect to the driver a view of the highway for a distance of at least 200 feet to the rear of such vehicle. Every motor vehicle subject to registration in this state, except a motorcycle, shall be equipped with not less than two such mirrors, including one affixed to the left-hand side. (b) The following described types of motor vehicles, of a type subject to registration, shall be equipped with mirrors on both the left-and right-hand sides of the vehicle so located as to reflect to the driver a view of the highway through each mirror for a distance of at least 200 feet to the rear of such vehicle: (1) A motor vehicle so constructed or loaded as to obstruct the driver's view to the rear. (2) A motor vehicle towing a vehicle and the towed vehicle or load thereon obstructs the driver's view to the rear. (3) A bus or trolley coach. (c) The provisions of subdivision (b) shall not apply to a passenger vehicle when the load obstructing the driver's view consists of passengers. |
So without the reverse lights, you wouldn't be able to see very well? I had my tails tinted and was considering putting in a camera but won't if there needs to be a light source to see.
that tight good thinking
looks good.
since it is a nightvison camera it can see about 10-15 feet without a light source. when I hit my brakes or reverse it really lights up the back.
I'm about to do this mod (I have the camera and monitor, which I'm mounting in the passenger cubby anlged so that I can see it). Can you go over the wiring for this mod? Did you use any relays or regulators? I know I'm going to be using the reverse light wires, but I don't want to fry the wires or the camera. Also, how did you wire it if you have a DVD or other video source hooked up to the monitor? I want to hook a DVD player up to it, but have the signal switch to my camera when I'm in reverse (I'm guessing that's how yours works). Thanks!
I wonder how the cameras that have their own light source would work? Might give better veiw at night.
B, you are so crazy. Install looks awsome, thou, i almost think you knew what you were doing, hmmmm. Bring it by so i can check yet another crazy mod, in person. B.
i just installed the same camera i highly recommend it...and it rickety rocks! congrats..good deal for 50 bucks!
I have my camera hooked up to the rear wiper switch up front so I can turn the camera on/off when I want to. the rear wiper power wires are still back in the hatch. one wire stays 12v switched and the other wire switches to ground when you turn on the rear wiper switch up front. if you want to switch the camera on/off with the wiper switch you will need a relay:
take the white/blue wire of the 2 pin connector of the wiper motor connector (switched ground wire from switch up front) and hook it up to pin 85 on the relay. take pin 86 and 87 of the relay and connect it to the other wire of the 2 pin connector (I think it's black) take pin 30 of the relay and connect it to the 12v (+) wire of the camera. take the ground wire of the camera and connect it to a bolt in the hatch to ground it now when you start the car you can turn on/off the camera with the rear wiper switch up front. as for running DVD through the monitor, the Monkey Video monitor I have has 2 inputs, AV1 and AV2. AV1 I used for the camera, AV2 I ran to my JVC flip out radio so I can play video through it. all I have to do is use the remote that came with the monitor and switch it back and forth. |
thats really sick man, cool idea.
