new system
Old Feb 8, 2008 | 04:24 AM
NYxBNV's Avatar
Default new system
Hey guys just wondering a few things. I am running an Alpine IVA-W205. I am thinking about getting two 8 or 10L7 subs. Is anyone running these with a JL 500/1. This is what I am thinking of running in my XB. Any help/suggestions let them fly.
Old Feb 14, 2008 | 02:36 AM
diablo243's Avatar
What are the specs on the subs? I have recently done a ton of research on amps and sub, best methods for matching.. yada yada... The 500.1 should drive 2 - 8s or even 10s fine, consider getting dual voice coil subs to give you the greatest flexibility in wiring and consider your subs ohms based on amp specs. Another words if you want to run your subs at 2ohms, A. make sure your amp is 2ohm or even 1 ohm stable B. be sure you wire your subs properly for the ohms you want. Wiring the subs in different configs gives you different resistance. Check out www.the12volt.com there is a ton of info that will help you spec, install and wire properly. Good Luck!
yhwhdesign
Jun 11, 2021 03:34 PM
carid
Feb 10, 2019 10:46 PM
Hydryman
Feb 23, 2016 03:35 PM
brett561tc
Sep 15, 2015 06:33 AM
Subaru86
Jul 31, 2015 04:33 AM
