potentiometer/dimmer switch (now with installed pics)
Old Jan 2, 2006 | 12:16 AM
jct's Avatar
jct
Default potentiometer/dimmer switch (now with installed pics)
well to make a long story even longer errrrr i mean shorter
has anybody put a rheostat/dimmer switch on there under dash leds??? if so got pics???
i did a search and came up empty a quite a few dimmer switch ideas for ccfl's but those got shot down
Old Jan 6, 2006 | 04:21 AM
jct's Avatar
jct
imma gonna be installing this when i do my under dash leds install when ever i get my leds
i used a cold soldering iron and its a freakin a blast to use ans easy too i improved my soldering skills from 25% to around 90%!!!
20 bucks for a cold soldering iron its my new best friend haha
i do a crummy job with the old soldering irons a poor job at that!!!
http://kitsrus.com/kits.html#k68
camera black out had to use the batteries in the cold soldering iron haha
5k ohm potentiometer / rheostat / dimmer switch
all together now all purdy like
wires from the top - goes to power, side - to potentiometer, bottom - output...
i mutalated a gardner bender gsw-45 switch to fit my potentiometer
Old Jan 8, 2006 | 11:53 PM
jct's Avatar
jct
installed the wiring today, it was slightly a p.i.t.a. to do
i installed my adjustable voltage power supply (dimmer control) box behind (in front of whatever its closest to the firewall) its right next to the airbag sensor assembly
i used my test led to test it out (its from one of those one led bulb flash lights)
don't mind the blue color thats coming from the leds either from the cup holders or the eazy bake oven
Old Jan 9, 2006 | 04:28 AM
Spr0ket's Avatar
Awesome writeup Hornet. I say this needs a tech section.
Old Jan 9, 2006 | 06:58 PM
HeathenBrewing's Avatar
Umm...not sure if you know this or not, but if you run the power to the center console, you can use the same dimmer that is used for the dash lights.
Old Jan 9, 2006 | 08:21 PM
jct's Avatar
jct
i already knew that, i have my cup holder lights and my eazy bake oven lights hooked up too 'em, i wanted a different control for the under dash leds
Old Jan 9, 2006 | 10:33 PM
Big_Bird's Avatar
wow dude, totally trick, good work
Old Jan 10, 2006 | 01:03 AM
jct's Avatar
jct
Old Jan 10, 2006 | 01:11 AM
jallamas's Avatar
Old Jan 27, 2006 | 11:23 PM
jct's Avatar
jct
would of posted a short video but it turned out pretty crummy but it works great!!!
jaspercanda
Scion tC 2G Aero & Exterior
14
Feb 3, 2020 02:43 PM
LzeroKI
Scion tC 1G Aero & Exterior
Feb 10, 2015 07:28 PM
IrjI619
Dec 21, 2014 05:04 AM
randode
44
Jun 29, 2004 04:19 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
