Power Inverter
Power Inverter
i'm installing my audio equipment and ps2 next weekend and was told i would need a power inverter. what are you guys using, what's the price, where can i get one for a good price, and how do you hook them up? if possible, i'd like something pretty small since the ones i've seen are pretty big and i want it to be hidden. thanks.
I got a 400w inverter for $40 from Advance Auto Parts. It's small and light, so I'll probably strap it under one of the front seats. Also, make sure you get a sine wave inverter and not a square wave. Some of the guys who used square wave inverters with an Xbox had issues.
If you are going to run a 400w inverter, DO NOT wire it into your fuse box. instead, tap it to your ignition harness on the accessory or ignition wire and make sure you fuse it. The 400W inverter I have came with 10 gauge wiring in it to hook up. If you try to run anything smaller and have too much of a pull, you will melt wires/fuseboxes. I have seen it from people incorrectly fusing things and believe me, it is no fun to peal up melted plastic out of carpet.
keeping it wired to the battery can drain it over night if theres no manual off and on switch. but that is something i would do, direct connection to the battery with an off and on switch closs to my fingers for easy access.
i'll be using one of these http://www.cardomain.com/item/PILPLSW15B
placing it right next to where the scion illumination light switch is at and just infront of the AUX audio plugin.
most switches are going to be rated 10-20amp at 110-125v. this basicly translates to 100-200amp at about 12v so if you go that route you don't need to worry about ratings unless you intend to install a 1,200+ watt inveter.
wire it to the battery, but run it thru a relay triggered by the ignition. that way it's drawing current from the battery (where it won't starve your dash wiring and possible overload the circuit) but it'll still shut down when you turn the car off.
i have a 400w inverter under my driver's seat and i trigger it with my deck's remote output..
ScionLife Editor
02-25-2015 04:40 PM
crystaljukebox_com
02-05-2004 05:53 AM
