question: installing factory bazooka in an RS3
Does anyone know if the factory bazooka tube will plug and play into the Alpine HU that comes in the RS3? I have the harness but don't know if it works with the upgraded Alpine. I just wanted to check before I wasted my time ripping everything apart this weekend!
Sorry for the dumb question. I know nothing about this stuff. I searched for awhile but couldn't find anything.
Thanks for the help! :D
I installed munes to the oem radio. Its fairly easy to do, just remove the center dash insert by the ac controls. Then at the rear of the radio is 3 connectors and I believe the middle one is the one you unplug and plug the bazooka cable into, then plug the radio connector into that and route it through the glove box area.
I put my bazooka behind the drivers seat and grounded it with one of the bolts on the parking brake handle mounting bolts.
sounds OK I guess. I don't know anything about subs so my review would be pointless. at least it's in finally!
It took me a week to get mines adjusted right. I have the cannon set to max, the bass on the radio set to 2 and most of the balance to the rear. I have the asl set high so 40 mph is the point where the bass kicks up and down the most. For the most part you do not hear it except on rap music and some metal. I like the extra umph it gives to the music, just wished it was smaller. Then again with my seat all the way back its not likely a passenger could sit behind me anyways, so that is where I have it positioned.
minter66
Dec 15, 2014 01:45 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
