radio help asap!!!
Old Jul 29, 2004 | 03:38 PM
Mr_scion's Avatar
N.G.S.O.
Default radio help asap!!!
i have a aftermarket radio and when i drive the radio gose in and out :? but when im at a stop light it picks up fine i put the fatory radio back in and it works fine n-e one know what i can do to fix it???
Old Jul 29, 2004 | 03:41 PM
SERG4U's Avatar
In and out......meaning that the power turns off?
Old Jul 29, 2004 | 03:45 PM
Guest
Guest
Posts: n/a
I believe theyre referring to reception. Some people make signal boosters so you pick up stations better, but something you should know is aftermarket radios seldom pick up station better than your stock radio will.
Old Jul 29, 2004 | 03:51 PM
Mr_scion's Avatar
N.G.S.O.
yea they told me i may need a booster but i want to see if n-e one knows of a free way to fix it :twisted:
Old Jul 29, 2004 | 03:57 PM
cAmmoBox's Avatar
What kind of aftermarket radio is it?
Old Jul 29, 2004 | 03:59 PM
randode's Avatar
Wagonistas
the stock antenna is in the glass. This is a powered antenna. You need to supply power to the antenna to make it work.
According to the wiring diagram, its a black and red wire.
Old Jul 29, 2004 | 04:44 PM
TheIcon's Avatar
Did you use a wiring harness to hook up your receiver? As was posted above make sure the power antenna is connected. I made the mistake when I installed my Kenwood DDX7015 of not connecting the power attenna and I had like 1 station. It was an obvious fix. :D
prescottn
Oct 8, 2015 05:31 PM
dyenfd
Sep 13, 2015 10:00 PM
rhino8648
Sep 6, 2015 04:04 AM
semlin
Jul 29, 2015 02:07 AM
