Rear Backup Camera
Old Apr 3, 2006 | 10:27 PM
  #41
TheIcon's Avatar
I wanted to thank Violent B for helping me out with this problem. He could have easily told me I was an idiot and stopped replying to my IMs yet he pressed forward and figured out my problem. Im greatful.
Def a great scionlife member
Old Apr 3, 2006 | 11:33 PM
  #42
violent_b's Avatar
so did it work?
Old Apr 3, 2006 | 11:39 PM
  #43
violent_b's Avatar
just read my PM. glad it worked out in the end. I'm just out there to help anyone who needs help, so they can enjoy their Scion as much as I do.
Old Apr 11, 2006 | 05:16 PM
  #44
greenguyshrek's Avatar
This also worked for me. It was pretty easy. I jsut followed what you said and it works fine.
Old Apr 12, 2006 | 01:03 AM
  #45
TXboxdriver's Avatar
can I(we) see this coveted PM'ed data
i'm all tingly cause i have all my parts for this weekend
and i really want to do this
Old Apr 12, 2006 | 02:21 AM
  #46
violent_b's Avatar
the diagram above is correct. the problem was the connector Icon took off his neon lights and pluged into the camera was wired backwards. so he had everything correct except that plug. a simple mistake, but sometimes those take longer to figure out.
crisis averted! now on to the next one...
Old Apr 12, 2006 | 04:11 AM
  #47
Malthorn's Avatar
The head unit I have will automatically switch to the camera when the car is in reverse. I was working on hooking it up today but didn't see anyplace obvious to hookup the wire. Anyone know where to hook it up?
Old Apr 12, 2006 | 11:36 AM
  #48
violent_b's Avatar
which wire are you talking about?
Old Apr 12, 2006 | 12:25 PM
  #49
thank you!
will post pics when(if) done
Old May 16, 2006 | 12:06 AM
  #50
150dBxB's Avatar
the camera i bought only has one wire on the power side and i hooked it up with the relay and all i get is white staticy noise
what am i doing wrong?
Old May 16, 2006 | 12:35 AM
  #51
violent_b's Avatar
was there a connector on the end, kinda looked like a rca but it isn't? if you cut that connector off, strip back the outside covering, you will have many strands of wire and another protected wire in the center. strip back the center protective covering and that is your (+) wire. the outter strands are your (-) wire.
now use the diagram above and you should be golden.
Old Jun 2, 2006 | 07:34 AM
  #52
sabot7726's Avatar
Does anyone know if the clip-on-the-rear-view-mirror setups work very well?
Old Oct 10, 2006 | 02:01 AM
  #53
Gardiner's Avatar
N.G.S.O.
I have my camera for the rear now, but I need to hook it into the reverse light circuit. Where is a good place to tie into the circuit?
Old Oct 10, 2006 | 10:16 AM
  #54
LEDMods_net's Avatar
Strictly Scionized
The reverse wire is red/black by the fuse box, but you can also use the positive wire from the reverse light bulb wire.
Old Jan 17, 2007 | 05:27 AM
  #55
scyon's Avatar
Not to bring up old subjects,But I Actually found this in a search I did for me... LOL ...Anywho I have been looking for a camera and now there are so many out there I am not sure on (Ebay) what one to get ? Please help.......
Thanks Eddie
Old Jan 17, 2007 | 06:58 AM
  #56
Thanks Eddie
This is the exact one that I bought. It works great.
http://cgi.ebay.com/ebaymotors/REARV...QQcmdZViewItem
Old Jan 17, 2007 | 12:43 PM
  #57
violent_b's Avatar
http://cgi.ebay.com/SUPERWIDE-ANGLE-...QQcmdZViewItem
this is like the one I got off ebay. it's a night vision camera so you can see out about 10-15 feet with no light. the one thing about the night vision cameras is that they are bigger then the wiper hole, so you will have to make the wiper hole bigger. but I will tell you the night vision is well worth the extra work.
Old Jan 18, 2007 | 04:06 AM
  #58
BradsTRDTC's Avatar
i did mine a while back/// it took me 30 mins to install the camera, hook it up to my double DIN Kenwood and wrap the back hatch with eDead.
Old Jan 18, 2007 | 11:54 AM
  #59
Sciond's Avatar
agreed mine is night vision and it rocks
Old Jan 18, 2007 | 06:34 PM
  #60
NastysXB's Avatar
can someone get a a closer pic of what the cameras look like in the hatch?
