removing the steering wheel
how easy is it to remove the steering wheel from its column? i know you have to remove the airbag first but do i then need any special tool or "elbow grease" to get the wheel off? thanks
Well, it is FREE to rent it. Just give them a deposit (which is usually the price to purchase the puller), and when you return it, you get your deposit back.
You would have to remove the airbag first. Usually on most steering wheels, there are two holes (one on each side), and you have to stick a flat screwdriver in there and twist (this release the clip for the bag). after the bag is off, just use the steering wheel puller. Its pretty straight forward from there.
Originally Posted by mat18
The airbag wont deploy if you pull the steering wheel off?
Thanks that was some good info, so much needed info because I want to change out my steering wheel because its ugly and does not feel right.
Originally Posted by xbbox
Where do you disconnect the airbag from?
while you people are on the steering wheel subject....how do you remove the two silver pieces on the 06 xB wheel? im going to paint them like i've painted the rest, but i was just curious before i go prying and breaking things lol.
here is a picuture of my interior and the pieces i want off.
