Scion tC iPod setup?
I've hooked up my iPod to my tC using a Neo Ion kit, but now I'm having trouble with the setup. Everything works properly, but there is still one thing wrong: there's no place for the wire that's connected to the iPod to pass through. When I try to put back the upper part of the console, the wire is sanwiched under and I'm worried it'll malfunction over time if it's kept squeezed like that. Can anyone help me on this one? If you have an iPod hooked to your tC, a pic and/or any help is definitely appreciated.
Originally Posted by sonic_va
Originally Posted by glitterboy
Try running it through the ebrake slot. That might work.
Originally Posted by XBman
drill a small hole...
Originally Posted by spydur
I'm desperate for cd quality sound from my Ipod.
I tried the Monster setup that hooks up to the lighter, but it sounded far worse than I imagined.
check out alpine's website
www.alpine1.com
I have my iPod connector run under the console. Then I took the armrest off and there's a "secret compartment" inside where the armrest connects to the console. I stuffed the rest of the wiring in there, and drilled a small hole to the inside of the center console where the other power outlet is. So I just put the iPod in there.
Originally Posted by Hitm@n
That Neo Ion kit can you control all the ipods functions from the radio? Do you see the text, like song title and all that good stuff?
Originally Posted by SnakeEyez
Still thinking about passing the wire though the area with the emergency brake, but it seems hard to accomplish.
1. remove shift ****
2. remove panel section around shift **** .. pinch and pull on the top two parts below the center controls, then work your way back, and pull the sides near the ebrake towards the back of the car.
3. pull e-brake up, and pull that section up by the change tray -- Yeah, you have to pull really hard for this one.. it's stubborn -- make sure your change tray is closed and your cup holders are empty!! . Once you get it.. work your way back.
Hope this helps!
Personally, I'm running my PIE auxuillary to the arm rest box where it'll plug into a Belkin charger with the line out near the charger... that way, all I have is the 'dock cable' to connect when I want to listen. No controls through the stereo, but that's fine with me. I can hold the iPod or its remote in my hand!
Hope it works for ya!
-K
Hope this helps!
-K
The shift **** screws off, everything else is just clips inside with enough outside to hold onto so you don't have to get technical. -- oh, but be sure to tie your cables down or secure them somehow -- wire-ties, or zip-ties -- you don't want it to get caught in your shifter or e-brake mechanism!
It's actually pretty easy.. I used to have to make adjustments to a low quality RCA-Stereo cable that I started with -- I was even tempted to try it at a stop light.. but never did.. cause, you never know.
-K
O5_TRD_tC
Feb 18, 2015 09:01 PM
gettoastedinthetoaster
Scion xB 2nd-Gen Wheel & Tire
Dec 29, 2014 11:39 PM
minter66
Dec 15, 2014 01:45 PM
lunchbx05
Dec 11, 2014 06:13 PM
Dmscomp8892
Scion tC 2G ICE & Interior
Nov 22, 2014 02:55 AM
