Solder will not stick
Old May 7, 2005 | 04:18 PM
Kaeon's Avatar
Default Solder will not stick
Ok im doing the Amber to White led mod tutorial, And I got everything apart I go to solder the led on and the solder will not stick to the material at all
https://www.scionlife.com/forums/vie...710&highlight=
^Those are the OEM leds then didn't even look soldered...
Any tips on what to do?
Old May 7, 2005 | 04:39 PM
Kaeon's Avatar
Im going to try some led holders..
Old May 7, 2005 | 04:53 PM
The_Instigator's Avatar
Use you dremel to scuff the areas you want to solder to. Thats the only way to get it to stick. And a tip for you...just use side cutters to pull off the stock LEDs and their tabs. There is no easy way to remove them so just rip em off of there. Thats what I had to do when I did mine.
Old May 7, 2005 | 06:18 PM
Kaeon's Avatar
So where are these solder points?
Old May 7, 2005 | 06:22 PM
engifineer's Avatar
Make sure you clean it, and heat the connection points, not the solder. I just posted a soldering tips post that may help you as well.
https://www.scionlife.com/forums/viewtopic.php?t=61793
Old May 8, 2005 | 01:07 AM
Kaeon's Avatar
Sweet I got it...
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
Mjdavis1994
Sep 21, 2015 04:42 AM
StxArOne
Scion xA Aero & Exterior
Aug 29, 2015 03:29 PM
Mjdavis1994
Jul 18, 2015 04:29 AM
