sound deadening. how much square footage is needed
anyone know how much sound deadening would be needed for a single layer application throughout the whole car?floor , roof , door panels , hatch.
yes i ahve sprayed many cars. It is very similar to spraying a car, don't do it right yoou'll get runs, or a whole bunch at the bottom. The spray was designed to get into tight areas, not do an entire vehicle, it will still work though. sometimes the spray costs more than laying sheet. The actual sheet material is much better.
Originally Posted by fireballfish
how big of a difference did you guys notice after install? I'm contemplating installing sound deadening material also
But that Dynamat Extreme is good **** though.
Just bought some Rammat60, not sure how it'll do yet. I'll post about it later.
I used fatmat in my xb. So far I have three door with two layers and the rear floor area done with one layer. I still have to do the pass side rear door and remove the front seats so I can do the rest of the floor. This stuff really does take some time to install, my fatmat sat around for weeks before I was motivated to do it.
I don't know about acoustical foam, don't think it's made for a car..but not for sure.
I used b-quiet extreme, pretty cheap, went on real easy, little to no smell, sticks like hell. Seems to quiet down the car nicely, although I only put it on the doors and floor. It is like 1/3 the cost of dynamat. I am sure people use dynamat b/c it may be better than the competition(from what some say), but way too damn expensive for a broke-___ guy like myself.
hey hotbox go to b-quiet.com or do a search on it because i dont know if that is the right spelling of the site. that is where i got my deadening at for a real low price and it is pretty good stuff.
Originally Posted by hotbox05
i know this is ghetto but what about acoustical foam. or minimal expanding foam. is it a viable cheapo option or am i smokin?
as far as the effectiveness of it, the dynamat extreme was ok for the inside of the car, but the outside sounded like ___, so I was talking to a good buddy of mine that works at a audio shop(its a chain of 5-6 of them) he said that they use great stuff on all their spl vans. so I was at walmart, and decided to pick up 2 cans to do my hatch. I used them both, its going to take alot of cans.
if you think about it, the foam will expand and press against the panels and hold them out, if they can't come on and they can't go farther out, then it won't rattle. ill let you know how it turns out, I need acouple more cans for the hatch.
i did the expansion foam in the trunk of my bonneville. turned out very well. what i wound up doing was goin to the local homedepot and pickin up some double expanding foam and spraying inside the trunk lid track (where the trunk sheet metal is welded to the trunk) and behind my tail lights. turned out very well, but i would reccomend using it along with the dynanat or whatever you use.
Jim
Jim
