Speaker removal?
Old Feb 25, 2006 | 12:03 AM
HungSolo's Avatar
Default Speaker removal?
How exactly do you get the factory speakers off in the door and rear?
Old Feb 25, 2006 | 12:04 AM
hotbox05's Avatar
rears are bolted in. the fronts need to drill the rivets through
Old Feb 25, 2006 | 12:07 AM
SoCalMike's Avatar
What he said.... I take it you picked up your speakers???
Old Feb 25, 2006 | 12:10 AM
HungSolo's Avatar
Ya....just gotta get some harnesses and adapters. Do you happen to know the exact speaker harness I need?
Old Feb 25, 2006 | 12:30 AM
dugzilla's Avatar
I cut out the center of my front door speakers with my dremel so I didn't have to put spacers in the doors. My 6.5's fit perfectly.
Old Feb 25, 2006 | 12:44 AM
SoCalMike's Avatar
The spacers are very easy to make and you can just solder the speakers up to the stock wire.
Old Feb 25, 2006 | 12:47 AM
HungSolo's Avatar
I dont know how to solder and I dont have the tools to make the spacers. So i gotta go the other route.
Old Feb 25, 2006 | 12:53 AM
tyrantcold's Avatar
okay soldering is idiot easy to do , you will need a soldering iron , eucentric soler and a little patience. you can get 2 out of 3 of these at radio shack.
easiest way to solder if your not very experience is to tie the exposed wires together then wrap a small amount of solder around the wires, then apply the hot iron to the tied wires , hold it on the wires long enough for the solder to melt on to the wires and leave a shinny appearnce
Carefull not to leave the iron on the wires for too long though it will sometimes heat it up enough to melt through the insulation. buy some heat shrink tube to cover the soldered area at radio shack too but be sure to put it on before tieing the wires. pm me if you got any other questions
Old Feb 25, 2006 | 01:25 AM
jallamas's Avatar
Could you kind of explain what and how you did this! Thanks.....
John
Old Feb 25, 2006 | 01:45 AM
lppro-xb's Avatar
i did the same thing just cut out the old speaker and drill piliot holes and screw the new ones in the same place the old ones were, and you can just use wire nuts and black tape insted of soldering, works fine i havent had any problams w/ mine...
Old Feb 26, 2006 | 05:55 AM
HungSolo's Avatar
If I were to cut out the old speaker and use the adapter...do I use a set of nuts and bolts to reattache it to the door?
Old Feb 26, 2006 | 02:26 PM
SoCalMike's Avatar
Yes... Do you own a jig saw and a drill?????
Old Feb 26, 2006 | 05:50 PM
HungSolo's Avatar
I have a drill but not a jigsaw.
Old Feb 27, 2006 | 01:08 AM
lppro-xb's Avatar
u dont need a jigsaw
just a drill and some self-tapping bolts
trikkonceptz
Jun 7, 2015 01:46 AM
dltjdgns66
Scion tC 1G ICE & Interior
Apr 15, 2015 07:59 AM
lunchbx05
Dec 29, 2014 07:53 PM
batute
Oct 7, 2003 04:20 AM
vpkb
Sep 30, 2003 07:48 AM
