SQ Question for a audio newb
Old Sep 14, 2006 | 03:01 PM
DFWDJ's Avatar
Default SQ Question for a audio newb
What would be the best economical set up for a strictly SQ system? I want range, but not ridiculous rattling bass.
Old Sep 14, 2006 | 03:08 PM
LEDMods_net's Avatar
Strictly Scionized
You would have to stage everything for some primo SQ.
I would suggest getting some kick panel speaker boxes made, getting some good components (maybe Pioneer's PRS series speakers, or Alpine's Type R speakers), a good head unit with good audio control...
What's your economical budget?
Old Sep 14, 2006 | 03:09 PM
Chuck_Norris's Avatar
I guess the first question is your budget.
Old Sep 14, 2006 | 03:10 PM
DFWDJ's Avatar
Old Sep 14, 2006 | 03:25 PM
Strictly Scionized
I would suggest going with the Alpine Type R setup.
It is less expensive than the Pioneer route, and will still give you great sound quality.
These component speakers will be great. Alpine SPR-17LS
http://www.alpine-usa.com/en/product...model=SPR-17LS
This amp will be right for the speakers. Alpine MRP-F450
http://www.alpine-usa.com/en/product...model=MRP-F450
I would suggest getting some kick panels made if you really want it to sound nice. You can just have them installed in the door, and they will sound good, but kick panels will be better for staging.
For a head unit, you will probably have to go with a regular cd player (no in-dash) to stay in your budget.
Old Sep 14, 2006 | 03:30 PM
DFWDJ's Avatar
Certainly there must be a head unit without the lcd screen/dvd capabilities that has true SQ functionality as far as audio controls go that fits within my budget. Any suggestions?
Old Sep 14, 2006 | 03:41 PM
Strictly Scionized
Old Sep 14, 2006 | 03:49 PM
UV7's Avatar
UV7
First, ditch the stock headunit. Check out Eclipse or Alpine for a replacement.
Next, check out JL's component sets, the XR and ZR series. These sets sound exceptional when backed up with a good, clean class A/B amp, such as a JL 300/4 or A4300.
After, consider adding a 10" sub. I recommend using JL there as well. JL's W6v2 series woofs are designed with quality and quantity in mind, not just eardrum-popping bass, although they can do that as well. Back that up with a JL A1800 or 500/1 and you'll be in business.
According to those in the know, JL's "slash" series amps may be too much for the stock (crappy) charging system of the xB to handle. It is probably better that you consider the "A" series first. They are comparable in power and will provide great sound quality without destroying your alternator.
For an xB, avoid kickpanels. The concept of kicks is to lengthen the distance of the component from your ear, thereby creating a better stereo image by balancing the distances between R & L and the listeners' ears. Unfortunately, kicks in an xB would put your stereo image very low and not give the best in stereo imaging. Kicks are best used in cars that seat the driver and passenger more horizontally, such as a tC or Camaro.
For the xB, you are better off with components in the doors, with the mid angled upward to raise the stage. Installing the tweeter higher up on the door and angling it so that it deflects off the windshield will help to raise the sound stage as well. Be careful here. You do not want the tweeter too far from the mid as it will create a "separation" of the stage based on frequencies; i.e., lower sounds such as a bass guitar or kickdrum will seem to come from lower in the dash, while the snap of a snare or higher vocals will seem to come from the windshield.
Old Sep 14, 2006 | 04:00 PM
DFWDJ's Avatar
^^Good info, thanks!
Old Sep 14, 2006 | 04:02 PM
Sciond's Avatar
here you go simple...
2 Image Dynamic horns up front under the dash.. 2-8" subs under the seats and use one good 4 channel amp and a good line level and or a line driver/eq if budget allows
simple to install anyone can do this easy
it will play loud with decent sound quality and no power compression issues
Old Sep 14, 2006 | 04:10 PM
UV7's Avatar
UV7
Awesome. I haven't heard anyone mention ID's or USD WaveGuides in years. I did a few of those in some installs years ago and they do provide a great stage. They do need some sort of EQing, as they respond a little differently in every car.
...and I almost forgot... eDead or Dynamat the box before you install the stereo gear. You'll be glad you did.
Old Sep 14, 2006 | 06:47 PM
Sciond's Avatar
sometimes people forget good technology
Old Sep 14, 2006 | 10:22 PM
DFWDJ's Avatar
Thanks guys, now I have a starting point.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
