stamped emblem
Does anyone know how to create that kind of stamped emblem look that people usually stamp things such as logos into various materials. Usually I see things pressed into leather.
are you talking about something like this?
check here
https://www.scionlife.com/forums/viewtopic.php?t=16922
check here
Yep that is what I am talking about. :D Call me dumb but i am a little lost on the diagrams and directions. Can anyone spell it out a little bit better for me. Sorry I use to ride the short bus.
On leather stuff, I think they usually put the letters behind the material and stretch it. Mike (rolex87?) has something like that on his audio setup, maybe he can give more info.
Kinda hard to see in the pic, down along the bottom...
It's usually a hard foam you put behind the material, you can cut the foam into any shape you want and stick it to the surface you are wrapping. Then ou stretch your material over it and you have a 3D looking shape or logo. This is most often seen when being used with tweed...as all of you fellow mini-truckers already know.
-Z
-Z
Jeff
Where would I get this foam stuff? I will probably try and contact that one guy to see how he did it. Do you think it will work with the material on the scion? I am thinking no but I never have done it before so I really don't know.
Anyways, as for the foam stuff. I'm sure you can find it at Hobby Lobby or any other craft store.
And as for how you do it...it looks like you remove the headliner from the vehicle, then pull the headliner material from the backing, being careful not to tear the actual (rigid) headliner part.
Then you take your foam, cut whatever design you like, glue the design to your headliner board and let that set up.
Then take your material (what you will actually see as the headliner) and glue it to the headliner board using a roller to stetch out the material.
Let it all dry out and then re-install your new headliner.
This is an EXTREMLEY loose description and NOBODY here is responsible for what damage you may potentially do to your headliner, or whatever you may be doing this to.
The best way, if you are creatively inept, would be to have an upholstery place do it for you.
On a side note, if you plan to install a stereo or just want a quieter ride, you could apply sound deadner to your roof at this time
Here is a link to a lot of materials and the foam:
http://shop.store.yahoo.com/yourauto...ore/index.html
BTW if you stretch it TOO tight, you will smush the foam and it will look like booty.
-Z
-Z
killahXB2
Mar 29, 2016 04:22 AM
Subaru86
Jul 31, 2015 04:00 AM
