Stereo
If your amp will accept 4gauge get it. When it come it power wire the "BIGGER IS BETTER" statement holds true. The easier you amp get power the better it will preform. Just make sure you use the same gauge for the ground or you'll burn the amp out and possibly your car!!
Originally Posted by Trav5786
What size wire do I use to powe r& ground my amp is 12 gauge ok?
Read the manuel though
If your running 4gauge power wire you better be running 4gauge ground wire.
If your amp will take 4 ga then use it. Also you better use 4ga ground wire too. I would never use anything smaller than 8 ga except maybe on a powered bass tube which you could use 10 ga.
READ THIS
http://www.the12volt.com/info/recwirsz.asp
prescottn
Scion tC 2G ICE & Interior
Apr 26, 2016 01:14 AM
