Stereo Installation
Pull the temperature controls ***** off.
Remove the screws behind the left and right *****.
Push down on the top of the whole trip plate just inside of the air vents and pull out.
The only thing left are the 4 screws holding the stereo in.
Taken from the Camery Nav Install in the Tech section:
- To remove the radio, pull the 3 control ***** and remove the two brass screws there.
- Pull the entire radio bezel by grasping the plastic around the 2 vents and pulling with a fair amount of force. Next you will need to remove the 3 plugs connected to the radio bezel.
- After that, there are 4 screws holding the radio bracket in place, unscrew these 4 screws and pull the radio out. Finally, disconnect the 2 plugs and the antenna from the back.
- The radio is completely removed. Add your speed harness and install kit to complete the install.
wiltonhall
Jun 23, 2025 10:09 PM
reagan9000
Jan 28, 2015 06:20 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
