Stock Head Unit RCA Output Adapter
Old Jan 20, 2006 | 02:27 AM
pdrizzle's Avatar
DeepSouth Scions
Default Stock Head Unit RCA Output Adapter
Has anyone used one of these?
http://cgi.ebay.com/ebaymotors/2004-...QQcmdZViewItem
Old Jan 22, 2006 | 03:32 AM
integroid's Avatar
No but you can make one yourself for a little less. Just buy a male and female toyota harness and splice in two Low Level line adapters. I have something almost identical that I built for about $30 from ebay parts.
Old Jan 22, 2006 | 05:13 AM
jallamas's Avatar
G-nizzle here on SL sells them and they are plug and play, you can find his product on ebay or at www.norcalscion.com
John
Old Jan 26, 2006 | 04:58 AM
integroid's Avatar
Yes, but the one they sell is just a universal LOC. What the link points to is one that plugs between the factory harness and radio. This way you dont have to do any splicing. Just plug and play.
Old Jan 26, 2006 | 06:19 AM
I_dont_know's Avatar
I dont think i understand how those work. It uses the stock jacks in the back to basically splice in RCA's but where do you run the powered lines back to? You just wanna run subs, or do you want to run the 4 channel amp to push your mids and highs? Also, does it step down the power? You should check that stuff out, you dont wanna break somethin. What I did was run a LOC, completely cut the speaker wires, hooked the cut wires to the LOC, then ran the power lines back to the other ends of the inside speaker wires. I split the RCA's for the back to run my subs on my Profile 800sx amp, then the rear and front mids and highs on the two Profile 100sx amps. (I used a Scosche LOC which had RCA's for the front and rears. Simple trip to Wal-Mart)
Old Jan 31, 2006 | 03:32 AM
pdrizzle's Avatar
DeepSouth Scions
I just got mine in and it is awesome. I recommend this device to anyone using the stock radio with amps.
Old Jan 31, 2006 | 04:59 PM
SCI_TC_GUY's Avatar
I think the stock HU DOES have low level outputs(for the stock sub), just not in RCA form and nothing on the back of the HU.... this harness I believe taps into the stock sub-out that's inside the HU and gives you RCA...
Old Jan 31, 2006 | 05:18 PM
tanakasan's Avatar
LOC taps into the speaker outputs. Best spot is behind HU. You can disconnect OR leave the stock speakers connected. The LOC should not affect the output.
I "believe" that the bazooka sub uses high level signal as inputs. The stock HU does not have low level outputs resident. The harness carries power, ground and speaker level signal back to the sub location.
Old Feb 1, 2006 | 04:49 PM
SmokingTires's Avatar
I've got one of those and it works great!
Old Feb 2, 2006 | 12:02 AM
integroid's Avatar
I can make this setup for anyone that wants one. I can probably do them for about $35 plus shipping. I have enough harnesses to do 3 of them right now. PM me if interested.
Old Feb 2, 2006 | 07:02 AM
Or you could order them from Norcalscion.com and he has a reputable product and they are listed on ebay and it comes with every single thing you would need to hook up a subwoofer (email him for just the plain plug, its great deal) http://cgi.ebay.com/ebaymotors/SCION...spagenameZWDVW
Old Feb 3, 2006 | 08:23 PM
integroid's Avatar
I make the exact same thing this guy is selling on ebay with the exact same LOC soldered in. The only difference would be the price. Mine are about $10 cheaper than what he is selling.
wiltonhall
Jun 23, 2025 10:09 PM
clickclickw00t
Feb 18, 2015 08:57 PM
reagan9000
Jan 28, 2015 06:20 PM
lunchbx05
Dec 11, 2014 06:13 PM
ToyTuners
Feb 22, 2004 10:34 PM
