Stupid Question
Stupid Question
Ok... my orange cathodes are finally here. Now how do I wire up the switch? I'm tapping in to the cigarette lighter. Can anyone explain to me how to do it? I know I'm not the brightest, but do you connect the positive or the negative to the switch and does it matter what prong you use? I got the OEM switch from Oznium.
The most common method is to tap/splice the positive wire from the cigarette lighter to your switch and from the switch to the positive of the inverters. Ground the negative of the inverters near where you mount them. Get some wire taps from Wal-Mart or an auto parts place to do it. It doesn't matter which prong on the switch you use.
I already checked the tech section, but I couldn't find anything that went into detail. I did a search as well, with no luck. Ok... so you use the positive... is that the black with the white stripe or the white with the black stripe?
TylorWeaver
23
12-09-2003 04:59 AM
