Subs + Carbon Fiber Hatch= Any problems????
Old Nov 8, 2005 | 04:49 AM
StylinCavy's Avatar
Default Subs + Carbon Fiber Hatch= Any problems????
Im not sure if this question even makes sense, but I have a carbon hatch and am going to be getting some Alpine Type R 12's , are there any problems with the bass from the subs doing any harm to the hatch like cracking or anything?? Any help will be appreciated. Thanks in Advance!!
Old Nov 8, 2005 | 05:22 AM
Longoscion's Avatar
the motor fx hatch is great
Old Nov 8, 2005 | 11:33 AM
SCI_TC_GUY's Avatar
good question, although I would think the hatch manufacturers would give it enough strength to stand up to some woofer pressure....
Old Nov 8, 2005 | 04:19 PM
Reign_Man's Avatar
yes but how does carbon fiber handle various level and intesities of vibration from that bass?
Old Nov 8, 2005 | 04:28 PM
MuNkY's Avatar
Scion Apocalypse
I'll be dynamatting the hell out of my CF hatch when i get it.. i dont think it can handle 2 15's with 2k watts each lol. as far as rattles go anyway.
Old Nov 17, 2005 | 03:38 AM
StylinCavy's Avatar
Any other responses?
Old Nov 17, 2005 | 02:48 PM
INSIDEOUT's Avatar
where are you getting a TRUE 2000 WATT AMP AT is my question?
Old Nov 17, 2005 | 02:53 PM
SCI_TC_GUY's Avatar
^^^ it's not the question of where to get a 2000 watt amp, it's the question of what are you doing to the electrical to allow the amps to push out 2000 watts each....
Old Nov 17, 2005 | 04:48 PM
MuNkY's Avatar
Scion Apocalypse
2 yellow tops, 2 800 Battcaps, and 2x Diamond audio 2000.1's, i'm also having my alternator respooled here soon.
going to 2 diamond d9 15's
Old Nov 17, 2005 | 04:54 PM
SCI_TC_GUY's Avatar
how high are you upping your alternator?? sounds like a good course of action thus far though....
That's what alot of people don't understand...You can only get "X" amount of watts from a stock electrical system....If you go higher than that, You're running on a treadmill(not getting anywhere) without electrical upgrade....
Old Nov 17, 2005 | 05:30 PM
iNFEktEd's Avatar
i have the cf hatch and a 12 kicker L7 sub... it still sounds good... not too much vibrating... my oem hatch was dynomated... but too lazy to dynomat it again... everything seems fine except that nasty license plate rattle everyone hates... but i only hear it when i THUMB the ish outta my box. hope this helps.
Old Nov 17, 2005 | 05:51 PM
StylinCavy's Avatar
iNFEktEd, is your sub facing the hatch or up or which direction? And no problems with the hatch, good to hear, cause thats what im worried about.
Old Nov 17, 2005 | 06:55 PM
iNFEktEd's Avatar
teh sub is facing the hatch... it's a tight fit... only about an inch or two from the sub to the hatch.
Old Nov 17, 2005 | 07:21 PM
trebor's Avatar
Just a small sidetrack please, I just wanted to know if the CF hatch is a lightweight hatch(lighter than stock) or not. I've bought a few CF parts and my front lip and rear wing are both heavier than stock.
As for your question, if it rattles, simply use some kind of sound deadening material on it.
Old Nov 18, 2005 | 08:06 PM
redhalo's Avatar
Does anyone else find the humor in replacing the hatch with CF, usually for the purpose of losing weight and then installing loads of heavy audio equipment? Lol.
Old Nov 18, 2005 | 08:24 PM
foreverandaminute's Avatar
lol
Old Nov 18, 2005 | 08:28 PM
mandos's Avatar
Everytime this thread gets bumped.
If you're going for the look, then yeah, deaden away...
If you're saving weight.......
Old Nov 18, 2005 | 08:33 PM
redhalo's Avatar
I guess it's better than using a big cf sticker.
Old Nov 21, 2005 | 11:15 AM
SCI_TC_GUY's Avatar
^^indeed
tckid21
Mar 12, 2017 09:16 PM
DebbieS
Jan 27, 2015 06:27 AM
AbsoluteRedtC
Dec 31, 2014 06:18 PM
ExtremeDimensions
Dec 18, 2014 04:47 PM
umnitza
Dec 1, 2014 06:26 PM
