TC Wiring the Speakers
Old Nov 2, 2004 | 07:58 PM
rgrossman's Avatar
Default TC Wiring the Speakers
I ordered a wiring harness which should help with the power aspect. What I'm wondering is, how do you wire the 6 speakers into the 4 channels that most radios come with? Each speaker gets a channel, so do I need 6 channels to do this or is there a cross over of some sort in the car?
Old Nov 2, 2004 | 09:27 PM
iowagary's Avatar
I think that the tweeters and the front speakers are kinda spliced together, but I don't know if the tweeters have a highpass filter or something.
I would think that this is irrelevant though - if you're replacing your speakers, just attach them to the existing wires. If you're replacing the head unit, just attach the harness that's all ready. Unless you want to rewire the whole car, it doesn't matter.
Old Nov 2, 2004 | 10:21 PM
ChefRaekwon's Avatar
Well the front midbass and tweeter are wired together with some sort of inline crossover. So just wire it like a normal set up FR, FL, RR,RL. If your replacing the midbass and tweeter than you would need to run new wire to the front doors due to the inline crossover.
Old Nov 2, 2004 | 10:29 PM
iowagary's Avatar
What if you were replacing the existing midbass and tweeter with another midbass and tweeter - couldn't you use the existing wiring and crossover then?
Old Dec 13, 2004 | 02:30 AM
toyota_scion_tc's Avatar
not entirely sure but be carefull most head units are only good for a 4ohm load of you have two 4ohm speakes wire togeather your load is 2ohms and will push your head unit a lot harder. If might not be able to handle it. if could actually blow the speakers also. When an amp is rated at 40 watts @ 4 ohms and you wire it to 2 ohms it is now pushed to 80 watts.
airmankevin1
Feb 14, 2018 01:23 PM
jonny_b
Scion tC 1G ICE & Interior
May 2, 2015 01:45 PM
dltjdgns66
Apr 15, 2015 07:59 AM
clickclickw00t
Feb 18, 2015 08:57 PM
cwong1001
Dec 3, 2014 03:30 AM
