? for those that installed a head unit in the xB storage bin
I installed my new clarion deck in the storage bin under the stock head unit location. I got the idea from this forum and it's a great idea. It was a little more involved than I figured and the only issue I have is that the radio hits the air duct which is right behind the storage bin location. Not a big deal but I will probably grind down the coin holder on the fold down door for more clearance so I can close it with the faceplate installed.
Anyway, my question is, how did you guys secure the headunit in that location? Right now I have just a pressure fit and it's secure but can still be moved about with little effort. I need to secure it for insurance reasons so i'm looking for some ideas.
I used the metal install sleeve that comes with the head unit. I marked where 4 of those bending flaps were on the cubby hole, and then used a drill bit to make a hole in the cubby. Then you can bend the flaps in the sleeve up, which then locks the head unit in place.
Originally Posted by TOAST3R
https://www.scionlife.com/forums/viewtopic.php?t=27518
Originally Posted by junklr
Like this? Use back straps, and no need to grind anything!
I got power for the monitor from the stereo harness. You have a constant 12v and a switched 12v right there to run a relay off of. Prolly dont even need a relay, but I just wanted to put one in there.
ok people, i f*cked up. I destroyed my storage bin faceplate trying to cut a hole in it to have my head unit poke out of the storage bin. what do i do.... i guess i can put it there for now w/o the faceplate to do the install, but ill need to think of something.
wiltonhall
Jun 23, 2025 10:09 PM
clickclickw00t
Feb 18, 2015 08:57 PM
lunchbx05
Dec 11, 2014 06:13 PM
